配置文件管理器示例
下面的示例演示了 and 类的用法:AcApProfileManagerAcApProfileManagerReactor // Define a class derived from AcApProfileManagerReactor to manage
// the notifications.
class AsdkProfileManagerReactor : public AcApProfileManagerReactor
public:
void currentProfileWillChange(const char *newProfile);
void currentProfileChanged(const char *newProfile);
void currentProfileWillBeReset(const char *curProfile);
void currentProfileReset(const char *curProfile);
void profileWillReset(const char *profName);
void profileReset(const char *proName);
// Define the notification functions.
void
AsdkProfileManagerReactor::
acutPrintf("\nCurrent profile will change: %s", newProfile);
void
acutPrintf("\nCurrent profile changed: %s", newProfile);
void
acutPrintf("\nCurrent profile will be reset: %s", curProfile);
void
acutPrintf("\nCurrent profile has been reset: %s", curProfile);
void
acutPrintf("\nNon-current profile will be reset: %s", profName);
void
profileReset(const char *profName)
acutPrintf("\nNon-current profile has been reset:%s", profName);
void
aFunction()
acutPrintf("This is AsdkProfileSample Test Application...\n");
// Attach the reactor for the duration of this command. Normally
// this would be added upon application initialization.
AsdkProfileManagerReactor *pProfileRector =
new AsdkProfileManagerReactor();
acProfileManagerPtr()->addReactor(pProfileRector);
// Obtain the path for the registry keys and print it out.
char *pstrKey;
acProfileManagerPtr()->ProfileRegistryKey(pstrKey, NULL);
if (pstrKey != NULL) {
acutPrintf("\nThe profiles registry key is: %s", pstrKey);
acutDelString(pstrKey);
// Get the list of all profiles in the user's configuration
// and print them out.
AcApProfileNameArray arrNameList;
int nProfiles =
acProfileManagerPtr()->ProfileListNames(arrNameList);
acutPrintf("\nNumber of profiles currently "
"in the user profile list is: %d", nProfiles);
for (int i = 0; i < nProfiles; i++)
acutPrintf("\nProfile name is: %s", arrNameList[i]);
// Copy the unnamed profile to the AsdkTestProfile.
acProfileManagerPtr()->ProfileCopy(
"AsdkTestProfile",
"<<Unnamed Profile>>",
"This is a test");
// Reset the newly copied profile to AutoCAD defaults.
acProfileManagerPtr()->ProfileReset("AsdkTestProfile");
// Make this new profile current.
acProfileManagerPtr()->ProfileSetCurrent("AsdkTestProfile");
// Change a value in the profile. For this example, make the
// cursor big.
struct resbuf rbCursorSize;
rbCursorSize.restype = RTSHORT;
rbCursorSize.resval.rint = 100;
acedSetVar("CURSORSIZE", &rbCursorSize);
// Rename the profile to a new name.
acProfileManagerPtr()->ProfileRename(
"AsdkTestProfile2",
"AsdkTestProfile",
"This is another test");
// Export the profile.
acProfileManagerPtr()->ProfileExport(
"AsdkTestProfile2",
"./AsdkTestProfile2.arg");
// Import the profile.
acProfileManagerPtr()->ProfileImport(
"AsdkTestProfile3",
"./AsdkTestProfile2.arg",
"This is a copy of AsdkTestProfile2"
"by Exporting/Importing",
Adesk::kTrue);
// Remove the reactor.
acProfileManagerPtr()->removeReactor(pProfileRector);
父主题: |
GMT+8, 2026-10-28 01:11
