嵌套事务示例
下面的示例包括三个嵌套事务。事件的顺序如下。 创建嵌套事务
以下是此示例的代码: void
transactCommand()
Adesk::Boolean interrupted;
Acad::ErrorStatus es = Acad::eOk;
AcDbObjectId savedCylinderId,savedExtrusionId;
// Create a poly and post it to the database.
acutPrintf(_T("\nCreating a poly...Please supply the")
_T(" required input."));
if ((es = createAndPostPoly()) != Acad::eOk)
return;
// Start a transaction
AcTransaction *pTrans
= actrTransactionManager->startTransaction();
assert(pTrans != NULL);
acutPrintf(_T("\n\n###### Started transaction one. ######\n"));
// Select the poly and extrude it.
AcDbObject *pObj = NULL;
AsdkPoly *pPoly = NULL;
AcDb3dSolid *pSolid = NULL;
AcDbObjectId objId;
ads_name ename;
ads_point pickpt;
for (;;) {
switch (acedEntSel(_T("\nSelect a polygon: "), ename, pickpt))
case RTNORM:
acdbGetObjectId(objId, ename);
if ((es = pTrans->getObject(pObj, objId,
AcDb::kForRead)) != Acad::eOk)
acutPrintf(_T("\nFailed to obtain an object through transaction."));
actrTransactionManager->abortTransaction();
return;
assert(pObj != NULL);
pPoly = AsdkPoly::cast(pObj);
if (pPoly == NULL) {
acutPrintf(_T("\nNot a polygon. Try again"));
continue;
break;
case RTNONE:
case RTCAN:
return;
default:
continue;
break;
// Now that we have a poly, convert it to a region
// and extrude it.
acutPrintf(_T("\nWe will be extruding the poly."));
AcGePoint2d c2d = pPoly->center();
ads_point pt;
pt[0] = c2d[0]; pt[1] = c2d[1]; pt[2] = pPoly->elevation();
acdbEcs2Ucs(pt,pt,asDblArray(pPoly->normal()),Adesk::kFalse);
double height;
if (acedGetDist(pt, _T("\nEnter Extrusion height: "),
&height) != RTNORM)
return;
if ((es = extrudePoly(pPoly, height,savedExtrusionId)) != Acad::eOk) {
return;
// Create a cylinder at the center of the polygon of
// the same height as the extruded poly.
double radius = (pPoly->startPoint() - pPoly->center()).length() * 0.5;
pSolid = new AcDb3dSolid;
assert(pSolid != NULL);
pSolid->createFrustum(height, radius, radius, radius);
AcGeMatrix3d mat(AcGeMatrix3d::translation(pPoly->elevation()*pPoly->normal())*
AcGeMatrix3d::planeToWorld(pPoly->normal()));
pSolid->transformBy(mat);
// Move it up again by half the height along
// the normal.
AcGeVector3d x(1, 0, 0), y(0, 1, 0), z(0, 0, 1);
AcGePoint3d moveBy(pPoly->normal()[0] * height * 0.5,
pPoly->normal()[1] * height * 0.5,
pPoly->normal()[2] * height * 0.5);
mat.setCoordSystem(moveBy, x, y, z);
// Move it, so center of cylinder will equal center of poly
AcGePoint3d pt1;
pPoly->getCenter (pt1);
AcGeMatrix3d mat1(AcGeMatrix3d::translation(pt1 - AcGePoint3d ()));
pSolid->transformBy(mat1);
addToDb(pSolid, savedCylinderId);
actrTransactionManager->addNewlyCreatedDBRObject(pSolid);
pSolid->draw();
acutPrintf(_T("\nCreated a cylinder at the center of the poly."));
// Start another transaction. Ask the user to select
// the extruded solid followed by selecting the
// cylinder. Make a hole in the extruded solid by
// subtracting the cylinder from it.
pTrans = actrTransactionManager->startTransaction();
acutPrintf(_T("\n\n###### Started transaction two. ######\n"));
AcDb3dSolid *pExtrusion, *pCylinder;
if ((es = getASolid(_T("\nSelect the extrusion: "), pTrans,
AcDb::kForWrite, savedExtrusionId, pExtrusion))
!= Acad::eOk)
return;
assert(pExtrusion != NULL);
if ((es = getASolid(_T("\nSelect the cylinder: "), pTrans,
AcDb::kForWrite, savedCylinderId, pCylinder))
!= Acad::eOk)
return;
assert(pCylinder != NULL);
pExtrusion->booleanOper(AcDb::kBoolSubtract, pCylinder);
pExtrusion->draw();
acutPrintf(_T("\nSubtracted the cylinder from the extrusion."));
// At this point, cylinder is a NULL solid. We might
// as well erase it.
assert(pCylinder->isNull());
pCylinder->erase();
// Start another transaction and slice the resulting
// solid into two halves.
acutPrintf(_T("\n\n##### Started transaction three. ######\n"));
AcGeVector3d vec, normal;
AcGePoint3d sp,center;
pPoly->getStartPoint(sp);
pPoly->getCenter(center);
vec = sp - center;
normal = pPoly->normal().crossProduct(vec);
normal.normalize();
AcGePlane sectionPlane(center, normal);
AcDb3dSolid *pOtherHalf = NULL;
pExtrusion->getSlice(sectionPlane, Adesk::kTrue,
pOtherHalf);
assert(pOtherHalf != NULL);
// Move the other half three times the vector length
// along the vector.
moveBy.set(vec[0] * 3.0, vec[1] * 3.0, vec[2] * 3.0);
pOtherHalf->transformBy(mat);
AcDbObjectId otherHalfId;
addToDb(pOtherHalf, otherHalfId);
actrTransactionManager->addNewlyCreatedDBRObject(pOtherHalf);
pOtherHalf->draw();
pExtrusion->draw();
acutPrintf(_T("\nSliced the resulting solid into half and moved one piece."));
// After all this work, let's abort transaction three,
// so that we are back to the hole in the extrusion.
Adesk::Boolean yes = Adesk::kTrue;
if (getYOrN(_T("\nLet's abort transaction three, yes?")
_T(" [Y] : "), Adesk::kTrue, yes,interrupted) == Acad::eOk
&& yes == Adesk::kTrue)
acutPrintf(_T("\n\n$$$$$$ Aborting transaction three. $$$$$$\n"));
acutPrintf(_T("\nBack to the un-sliced solid."));
pExtrusion->draw();
TCHAR option[256];
acedGetKword(_T("\nHit any key to continue."), option);
} else {
acutPrintf(_T("\n\n>>>>>> Ending transaction three. <<<<<<\n"));
actrTransactionManager->endTransaction();
// Start another transaction (three again). This time
// slice the solid along a plane that is perpendicular
// to the plane we used last time. That's the slice
// we really wanted.
moveBy.set(normal[0] * 3.0, normal[1] * 3.0,
normal[2] * 3.0);
normal = vec;
normal.normalize();
sectionPlane.set(center, normal);
pOtherHalf = NULL;
pOtherHalf);
pOtherHalf->draw();
pExtrusion->draw();
acutPrintf(_T("\nSliced the resulting solid into half along a plane"));
acutPrintf(_T("\nperpendicular to the old one and moved one piece."));
// Now, optionally, let's end all the transactions.
yes = Adesk::kFalse;
if (getYOrN(_T("\nAbort transaction three? <No> : "),
Adesk::kFalse, yes,interrupted) == Acad::eOk
} else {
if (getYOrN(_T("\nAbort transaction two? <No> : "),
acutPrintf(_T("\n\n$$$$$$ Aborting transaction two. $$$$$$\n"));
acutPrintf(_T("\nBack to separate extrusion and cylinder."));
} else {
acutPrintf(_T("\n\n>>>>>> Ending transaction two. <<<<<<\n"));
if (getYOrN(_T("\nAbort transaction one? <No> : "),
acutPrintf(_T("\n\n$$$$$$ Aborting transaction one. $$$$$$\n"));
acutPrintf(_T("\nBack to just the Poly."));
} else {
acutPrintf(_T("\n\n>>>>>> Ending transaction one. <<<<<<\n"));
static Acad::ErrorStatus
createAndPostPoly()
int nSides = 0;
while (nSides < 3) {
acedInitGet(INP_NNEG, _T(""));
switch (acedGetInt(_T("\nEnter number of sides: "), &nSides))
case RTNORM:
if (nSides < 3)
acutPrintf(_T("\nNeed at least 3 sides."));
break;
default:
return Acad::eInvalidInput;
ads_point center, startPt, normal;
if (acedGetPoint(NULL, _T("\nLocate center of polygon: "),
center) != RTNORM)
startPt[0] = center[0];
startPt[1] = center[1];
startPt[2] = center[2];
while (asPnt3d(startPt) == asPnt3d(center)) {
switch (acedGetPoint(center,
_T("\nLocate start point of polygon: "), startPt)) {
case RTNORM:
if (asPnt3d(center) == asPnt3d(startPt))
acutPrintf(_T("\nPick a point different from the center."));
break;
default:
// Set the normal to the plane of the polygon to be
// the same as the z direction of the current ucs,
// i.e. (0, 0, 1) since we also got the center and
// start point in the current UCS. (acedGetPoint()
// returns in the current UCS.)
normal[X] = 0.0;
normal[Y] = 0.0;
normal[Z] = 1.0;
acdbUcs2Wcs(normal, normal, Adesk::kTrue);
acdbUcs2Ecs(center, center, normal, Adesk::kFalse);
acdbUcs2Ecs(startPt, startPt, normal, Adesk::kFalse);
double elev = center[2];
AcGePoint2d cen = asPnt2d(center),
start = asPnt2d(startPt);
AcGeVector3d norm = asVec3d(normal);
AsdkPoly *pPoly = new AsdkPoly;
if (pPoly==NULL)
return Acad::eOutOfMemory;
Acad::ErrorStatus es;
if ((es=pPoly->set(cen, start, nSides, norm, _T("transactPoly"), elev))!=Acad::eOk)
return es;
pPoly->setDatabaseDefaults(acdbHostApplicationServices()->workingDatabase());
postToDb(pPoly);
return Acad::eOk;
// Extrudes the poly to a given height.
extrudePoly(AsdkPoly* pPoly, double height, AcDbObjectId& savedExtrusionId)
// Explode to a set of lines
AcDbVoidPtrArray lines;
pPoly->explode(lines);
// Create a region from the set of lines.
AcDbVoidPtrArray regions;
AcDbRegion::createFromCurves(lines, regions);
assert(regions.length() == 1);
AcDbRegion *pRegion = AcDbRegion::cast((AcRxObject*)regions[0]);
assert(pRegion != NULL);
// Extrude the region to create a solid.
AcDb3dSolid *pSolid = new AcDb3dSolid;
pSolid->extrude(pRegion, height, 0.0);
for (int i = 0; i < lines.length(); i++) {
delete (AcRxObject*)lines[i];
for (int ii = 0; ii < regions.length(); ii++) {
delete (AcRxObject*)regions[ii];
// Now we have a solid. Add it to database, then
// associate the solid with a transaction. After
// this, transaction management is in charge of
// maintaining it.
pSolid->setPropertiesFrom(pPoly);
addToDb(pSolid, savedExtrusionId);
pSolid->draw();
return Acad::eOk;
getASolid(TCHAR* prompt,
AcTransaction* pTransaction,
AcDb::OpenMode mode,
AcDbObjectId checkWithThisId,
AcDb3dSolid*& pSolid)
AcDbObjectId objId;
ads_name ename;
ads_point pickpt;
for (;;) {
switch (acedEntSel(prompt, ename, pickpt)) {
case RTNORM:
if (objId != checkWithThisId) {
acutPrintf(_T("\n Select the proper solid."));
continue;
pTransaction->getObject(pObj, objId, mode);
pSolid = AcDb3dSolid::cast(pObj);
if (pSolid == NULL) {
acutPrintf(_T("\nNot a solid. Try again"));
continue;
break;
case RTNONE:
case RTCAN:
default:
continue;
break;
return Acad::eOk;
父主题: |
GMT+8, 2026-10-26 18:21
