使用数据库反应器
2024-5-18 17:57| 发布者: admin| 查看: 746| 评论: 0|原作者: admin|来自: AutoCAD
使用数据库反应器
下面的示例使用派生自 的 reactor 来跟踪数据库中当前对象的数量。它为 reactor 类实现了三个通知函数:、 和 。该函数将反应器添加到当前数据库。该函数从数据库中删除反应器并删除数据库反应器。AcDbDatabase-ReactorobjectAppended()objectModified()objectErased()watch_db()clear_reactors()
class AsdkDbReactor;
long gEntAcc = 0;            // Global entity count
AsdkDbReactor *gpDbr = NULL; // Pointer to database reactor
// Custom AcDbDatabaseReactor class for database
// event notification.
class AsdkDbReactor : public AcDbDatabaseReactor
public:
    virtual void objectAppended(const AcDbDatabase* dwg,
        const AcDbObject* dbObj);
    virtual void objectModified(const AcDbDatabase* dwg,
    virtual void objectErased(const AcDbDatabase* dwg,
        const AcDbObject* dbObj, Adesk::Boolean pErased);
// Called whenever an object is added to the database.
void
AsdkDbReactor::objectAppended(const AcDbDatabase* db,
    const AcDbObject* pObj)
    printDbEvent(pObj, "objectAppended");
    acutPrintf(" Db==%lx\n", (long) db);
    gEntAcc++;
    acutPrintf("Entity Count = %d\n", gEntAcc);
// Called whenever an object in the database is modified.
void
AsdkDbReactor::objectModified(const AcDbDatabase* db,
    printDbEvent(pObj, "objectModified");
// Called whenever an object is erased from the database.
void
AsdkDbReactor::objectErased(const AcDbDatabase* db,
    const AcDbObject* pObj, Adesk::Boolean pErased)
    if (pErased) {
        printDbEvent(pObj, "objectErased");
        gEntAcc--;
    } else {
        printDbEvent(pObj, "object(Un)erased");
        gEntAcc++;
// Prints the message passed in by pEvent; then
// calls printObj() to print the information about
// the object that triggered the notification.
void
printDbEvent(const AcDbObject* pObj, const char* pEvent)
    acutPrintf("  Event: AcDbDatabaseReactor::%s ", pEvent);
    printObj(pObj);
// Prints out the basic information about the object pointed
// to by pObj.
void
printObj(const AcDbObject* pObj)
    if (pObj == NULL) {
        acutPrintf("(NULL)");
        return;
    AcDbHandle objHand;
    char  handbuf[17];
    // Gets the handle as a string.
    pObj->getAcDbHandle(objHand);
    objHand.getIntoAsciiBuffer(handbuf);
    acutPrintf(
        "\n   (class==%s, handle==%s, id==%lx, db==%lx)",
        pObj->isA()->name(), handbuf,
        pObj->objectId().asOldId(), pObj->database());
// Adds a reactor to the database to monitor changes.
// This can be called multiple times without any ill
// effect because subsequent calls are ignored.
void
watchDb()
    if (gpDbr == NULL) {
        gpDbr = new AsdkDbReactor();
    acdbHostApplicationServices()->workingDatabase()->addReactor(
        gpDbr);
    acutPrintf(
        "  Added Database Reactor to "
        "acdbHostApplicationServices()->workingDatabase().\n");
// Removes the database reactor.
void
clearReactors()
    if (acdbHostApplicationServices()->workingDatabase() != NULL) {
            )->removeReactor(gpDbr);
        delete gpDbr;
        gpDbr = NULL;
// ObjectARX entry point function
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* appId)
    switch (msg) {
    case AcRx::kInitAppMsg:
        acrxDynamicLinker->unlockApplication(appId);
        acrxDynamicLinker->registerAppNotMDIAware(appId);
        acedRegCmds->addCommand("ASDK_NOTIFY_TEST",
            "ASDK_WATCH",
            "WATCH",
            ACRX_CMD_TRANSPARENT,
            watchDb);
            "ASDK_CLEAR",
            "CLEAR",
            clearReactors);
        break;
    case AcRx::kUnloadAppMsg:
        clearReactors();
        acedRegCmds->removeGroup("ASDK_NOTIFY_TEST");
        break;
    return AcRx::kRetOK;
  1. 使用反应器
GMT+8, 2026-10-27 16:49
