遍历字典条目
2024-5-18 17:56| 发布者: admin| 查看: 872| 评论: 0|原作者: admin|来自: AutoCAD
遍历字典条目
字典的迭代器类是 。以下代码摘录从命名对象字典中获取字典 (ASDK_DICT)。然后,它使用字典迭代器单步执行字典条目并打印存储的整数的值。最后,它删除迭代器并关闭字典。AcDbDictionaryIterator
void
iterateDictionary()
    AcDbDictionary *pNamedobj;
    acdbHostApplicationServices()->workingDatabase()
        ->getNamedObjectsDictionary(pNamedobj, AcDb::kForRead);
    // Get a pointer to the ASDK_DICT dictionary.
    AcDbDictionary *pDict;
    pNamedobj->getAt("ASDK_DICT", (AcDbObject*&)pDict,
        AcDb::kForRead);
    pNamedobj->close();
    // Get an iterator for the ASDK_DICT dictionary.
    AcDbDictionaryIterator* pDictIter = pDict->newIterator();
    AsdkMyClass *pMyCl;
    Adesk::Int16 val;
    for (; !pDictIter->done(); pDictIter->next()) {
        // Get the current record, open it for read, and
        // print its data.
        pDictIter->getObject((AcDbObject*&)pMyCl,
            AcDb::kForRead);
        pMyCl->getData(val);
        pMyCl->close();
        acutPrintf("\nintval is:  %d", val);
    delete pDictIter;
    pDict->close();
  1. 字典
GMT+8, 2026-10-27 16:03
