遍历表
2024-5-18 17:56| 发布者: admin| 查看: 794| 评论: 0|原作者: admin|来自: AutoCAD
遍历表
以下示例中的代码创建一个迭代器,用于遍历线型表中的符号表记录。它获取每条记录,打开它进行读取,获取线型名称,关闭记录,然后打印线型名称。最后,程序删除迭代器。
void
iterateLinetypes()
    AcDbLinetypeTable *pLinetypeTbl;
    acdbHostApplicationServices()->workingDatabase()
        ->getSymbolTable(pLinetypeTbl, AcDb::kForRead);
    // Create a new iterator that starts at table
    // beginning and skips deleted.
    AcDbLinetypeTableIterator *pLtIterator;
    pLinetypeTbl->newIterator(pLtIterator);
    // Walk the table, getting every table record and
    // printing the linetype name.
    AcDbLinetypeTableRecord *pLtTableRcd;
    char *pLtName;
    for (; !pLtIterator->done(); pLtIterator->step()) {
        pLtIterator->getRecord(pLtTableRcd, AcDb::kForRead);
        pLtTableRcd->getName(pLtName);
        pLtTableRcd->close();
        acutPrintf("\nLinetype name is:  %s", pLtName);
        free(pLtName);
    delete pLtIterator;
    pLinetypeTbl->close();
  1. 迭代器
GMT+8, 2026-10-28 19:36
