遍历块表记录
2024-5-18 17:56| 发布者: admin| 查看: 884| 评论: 0|原作者: admin|来自: AutoCAD
遍历块表记录
下面的示例演示如何循环访问块表记录中的元素并打印出这些元素。
该函数打开块表进行读取,然后打开用户提供的块名称。新的迭代器单步执行块表记录。如果记录包含实体,则迭代器将打印有关该实体的消息。printAll()
void
printAll()
    int rc;
    char blkName[50];
    rc = acedGetString(Adesk::kTrue,
        "Enter Block Name <CR for current space>: ",
        blkName);
    if (rc != RTNORM)
        return;
    if (blkName[0] == '\0') {
        if (acdbHostApplicationServices()->workingDatabase()
            ->tilemode() == Adesk::kFalse) {
            struct resbuf rb;
            acedGetVar("cvport", &rb);
            if (rb.resval.rint == 1) {
                strcpy(blkName, ACDB_PAPER_SPACE);
            } else {
                strcpy(blkName, ACDB_MODEL_SPACE);
        } else {
    AcDbBlockTable *pBlockTable;
        ->getSymbolTable(pBlockTable, AcDb::kForRead);
    AcDbBlockTableRecord *pBlockTableRecord;
    pBlockTable->getAt(blkName, pBlockTableRecord,
        AcDb::kForRead);
    pBlockTable->close();
    AcDbBlockTableRecordIterator *pBlockIterator;
    pBlockTableRecord->newIterator(pBlockIterator);
    for (; !pBlockIterator->done();
        pBlockIterator->step())
        AcDbEntity *pEntity;
        pBlockIterator->getEntity(pEntity, AcDb::kForRead);
        AcDbHandle objHandle;
        pEntity->getAcDbHandle(objHandle);
        char handleStr[20];
        objHandle.getIntoAsciiBuffer(handleStr);
        const char *pCname = pEntity->isA()->name();
        acutPrintf("Object Id %lx, handle %s, class %s.\n",
            pEntity->objectId(), handleStr, pCname);
        pEntity->close();
    delete pBlockIterator;
    pBlockTableRecord->close();
    acutPrintf("\n");
GMT+8, 2026-10-26 18:22
