处理文档事件 (.NET)
Document对象事件用于响应文档窗口。注册文档事件时,它仅与与其关联的文档对象相关联。因此,如果需要将事件注册到每个文档中,则需要使用对象的事件来注册每个新图形或打开的图形的事件。DocumentCreatedDocumentCollection 以下事件可用于对象:Document
启用 Document 对象事件下面的示例使用该事件提示用户是否要继续关闭当前图形。将显示一个消息框,其中包含“是”和“否”按钮。单击“否”将使用事件处理程序返回的参数的方法中止图形的关闭。BeginDocumentCloseVeto VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("AddDocEvent")> _
Public Sub AddDocEvent()
'' Get the current document
AddHandler acDoc.BeginDocumentClose, AddressOf docBeginDocClose
<CommandMethod("RemoveDocEvent")> _
Public Sub RemoveDocEvent()
RemoveHandler acDoc.BeginDocumentClose, AddressOf docBeginDocClose
Public Sub docBeginDocClose(ByVal senderObj As Object, _
ByVal docBegClsEvtArgs As DocumentBeginCloseEventArgs)
'' Display a message box prompting to continue closing the document
If System.Windows.Forms.MessageBox.Show( _
"The document is about to be closed." & _
vbLf & "Do you want to continue?", _
"Close Document", _
System.Windows.Forms.MessageBoxButtons.YesNo) = _
System.Windows.Forms.DialogResult.No Then
docBegClsEvtArgs.Veto()
End If
End If
[CommandMethod("AddDocEvent")]
public void AddDocEvent()
// Get the current document
acDoc.BeginDocumentClose +=
new DocumentBeginCloseEventHandler(docBeginDocClose);
[CommandMethod("RemoveDocEvent")]
public void RemoveDocEvent()
acDoc.BeginDocumentClose -=
public void docBeginDocClose(object senderObj,
DocumentBeginCloseEventArgs docBegClsEvtArgs)
// Display a message box prompting to continue closing the document
if (System.Windows.Forms.MessageBox.Show(
"The document is about to be closed." +
"\nDo you want to continue?",
"Close Document",
System.Windows.Forms.MessageBoxButtons.YesNo) ==
System.Windows.Forms.DialogResult.No)
docBegClsEvtArgs.Veto();
VBA/ActiveX 代码参考Private Sub AcadDocument_BeginDocClose(Cancel As Boolean)
' This procedure intercepts the Document BeginDocClose event.
If MsgBox("The document is about to be closed." & _
vbLf & "Do you want to continue?", vbYesNo, _
"Close Document") = vbNo Then
' Veto the document close
Cancel = True
End If
相关概念父主题: |
GMT+8, 2026-11-15 11:46
