编辑 3D 实体 (.NET)
创建实体后,可以通过组合或减去实体来创建更复杂的形状。您可以连接实体、相互减去实体或求实体的公共体积(重叠部分)。使用该方法执行这些组合。该方法允许您确定两个实体是否重叠。BooleanOperationCheckInterference ![]() 通过获得实体的 2D 横截面或将实体切成两块来进一步修改实体。使用该方法求固体的横截面,以及将实体切成两块的方法。GetSectionSlice 求出两个实体之间的干涉本示例创建一个方框和圆柱体。然后,它找到两个固体之间的干涉,并从该干涉中创建一个新的固体。为了便于查看,盒子是白色的,圆柱体是青色的,干涉固体是红色的。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("FindInterferenceBetweenSolids")> _
Public Sub FindInterferenceBetweenSolids()
'' Get the current document and database, and start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a 3D solid box
Using acSol3DBox As Solid3d = New Solid3d()
acSol3DBox.CreateBox(5, 7, 10)
acSol3DBox.ColorIndex = 7
'' Position the center of the 3D solid at (5,5,0)
acSol3DBox.TransformBy(Matrix3d.Displacement(New Point3d(5, 5, 0) - _
Point3d.Origin))
acBlkTblRec.AppendEntity(acSol3DBox)
acTrans.AddNewlyCreatedDBObject(acSol3DBox, True)
'' Create a 3D solid cylinder
'' 3D solids are created at (0,0,0) so there is no need to move it
Using acSol3DCyl As Solid3d = New Solid3d()
acSol3DCyl.CreateFrustum(20, 5, 5, 5)
acSol3DCyl.ColorIndex = 4
acBlkTblRec.AppendEntity(acSol3DCyl)
acTrans.AddNewlyCreatedDBObject(acSol3DCyl, True)
'' Create a 3D solid from the interference of the box and cylinder
Dim acSol3DCopy As Solid3d = acSol3DCyl.Clone()
'' Check to see if the 3D solids overlap
If acSol3DCopy.CheckInterference(acSol3DBox) = True Then
acSol3DCopy.BooleanOperation(BooleanOperationType.BoolIntersect, _
acSol3DBox.Clone())
acSol3DCopy.ColorIndex = 1
End If
acBlkTblRec.AppendEntity(acSol3DCopy)
acTrans.AddNewlyCreatedDBObject(acSol3DCopy, True)
End Using
End Using
'' Save the new objects to the database
acTrans.Commit()
End Using
[CommandMethod("FindInterferenceBetweenSolids")]
public static void FindInterferenceBetweenSolids()
// Get the current document and database, and start a transaction
// Open the Block table record for read
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a 3D solid box
using (Solid3d acSol3DBox = new Solid3d())
acSol3DBox.CreateBox(5, 7, 10);
acSol3DBox.ColorIndex = 7;
// Position the center of the 3D solid at (5,5,0)
acSol3DBox.TransformBy(Matrix3d.Displacement(new Point3d(5, 5, 0) -
Point3d.Origin));
acBlkTblRec.AppendEntity(acSol3DBox);
acTrans.AddNewlyCreatedDBObject(acSol3DBox, true);
// Create a 3D solid cylinder
// 3D solids are created at (0,0,0) so there is no need to move it
using (Solid3d acSol3DCyl = new Solid3d())
acSol3DCyl.CreateFrustum(20, 5, 5, 5);
acSol3DCyl.ColorIndex = 4;
acBlkTblRec.AppendEntity(acSol3DCyl);
acTrans.AddNewlyCreatedDBObject(acSol3DCyl, true);
// Create a 3D solid from the interference of the box and cylinder
Solid3d acSol3DCopy = acSol3DCyl.Clone() as Solid3d;
// Check to see if the 3D solids overlap
if (acSol3DCopy.CheckInterference(acSol3DBox) == true)
acSol3DBox.Clone() as Solid3d);
acSol3DCopy.ColorIndex = 1;
acBlkTblRec.AppendEntity(acSol3DCopy);
acTrans.AddNewlyCreatedDBObject(acSol3DCopy, true);
// Save the new objects to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub FindInterferenceBetweenSolids()
' Define the box
Dim boxObj As Acad3DSolid
Dim length As Double
Dim width As Double
Dim height As Double
Dim center(0 To 2) As Double
center(0) = 5: center(1) = 5: center(2) = 0
length = 5
width = 7
height = 10
' Create the box object in model space
' and color it white
Set boxObj = ThisDrawing.ModelSpace. _
AddBox(center, length, width, height)
boxObj.Color = acWhite
' Define the cylinder
Dim cylinderObj As Acad3DSolid
Dim cylinderRadius As Double
Dim cylinderHeight As Double
center(0) = 0: center(1) = 0: center(2) = 0
cylinderRadius = 5
cylinderHeight = 20
' Create the Cylinder and
' color it cyan
Set cylinderObj = ThisDrawing.ModelSpace. _
AddCylinder(center, cylinderRadius, cylinderHeight)
cylinderObj.Color = acCyan
' Find the interference between the two solids
' and create a new solid from it. Color the
' new solid red.
Dim solidObj As Acad3DSolid
Set solidObj = boxObj.CheckInterference(cylinderObj, True)
solidObj.Color = acRed
ZoomAll
将固体切成两个固体本示例在模型空间中创建一个框。然后,它根据由三个点定义的平面对盒子进行切片。切片以 3DSolid 的形式返回。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("SliceABox")> _
Public Sub SliceABox()
OpenMode.ForRead)
OpenMode.ForWrite)
Using acSol3D As Solid3d = New Solid3d()
acSol3D.CreateBox(5, 7, 10)
acSol3D.ColorIndex = 7
acSol3D.TransformBy(Matrix3d.Displacement(New Point3d(5, 5, 0) - _
Point3d.Origin))
acBlkTblRec.AppendEntity(acSol3D)
acTrans.AddNewlyCreatedDBObject(acSol3D, True)
'' Define the mirror plane
Dim acPlane As Plane = New Plane(New Point3d(1.5, 7.5, 0), _
New Point3d(1.5, 7.5, 10), _
New Point3d(8.5, 2.5, 10))
Dim acSol3DSlice As Solid3d = acSol3D.Slice(acPlane, True)
acSol3DSlice.ColorIndex = 1
acBlkTblRec.AppendEntity(acSol3DSlice)
acTrans.AddNewlyCreatedDBObject(acSol3DSlice, True)
End Using
acTrans.Commit()
End Using
[CommandMethod("SliceABox")]
public static void SliceABox()
using (Solid3d acSol3D = new Solid3d())
acSol3D.CreateBox(5, 7, 10);
acSol3D.ColorIndex = 7;
acSol3D.TransformBy(Matrix3d.Displacement(new Point3d(5, 5, 0) -
Point3d.Origin));
acBlkTblRec.AppendEntity(acSol3D);
acTrans.AddNewlyCreatedDBObject(acSol3D, true);
// Define the mirror plane
Plane acPlane = new Plane(new Point3d(1.5, 7.5, 0),
new Point3d(1.5, 7.5, 10),
new Point3d(8.5, 2.5, 10));
Solid3d acSol3DSlice = acSol3D.Slice(acPlane, true);
acSol3DSlice.ColorIndex = 1;
acBlkTblRec.AppendEntity(acSol3DSlice);
acTrans.AddNewlyCreatedDBObject(acSol3DSlice, true);
acTrans.Commit();
VBA/ActiveX 代码参考Sub SliceABox()
Dim width As Double
center(0) = 5#: center(1) = 5#: center(2) = 0
length = 5#: width = 7: height = 10#
' Create the box (3DSolid) object in model space
' Define the section plane with three points
Dim slicePt1(0 To 2) As Double
Dim slicePt2(0 To 2) As Double
Dim slicePt3(0 To 2) As Double
slicePt1(0) = 1.5: slicePt1(1) = 7.5: slicePt1(2) = 0
slicePt2(0) = 1.5: slicePt2(1) = 7.5: slicePt2(2) = 10
slicePt3(0) = 8.5: slicePt3(1) = 2.5: slicePt3(2) = 10
' slice the box and color the new solid red
Dim sliceObj As Acad3DSolid
Set sliceObj = boxObj.SliceSolid _
(slicePt1, slicePt2, slicePt3, True)
sliceObj.Color = acRed
ZoomAll
父主题: |
GMT+8, 2026-10-27 13:25
