转换坐标 (.NET)
该方法可以将点或位移从一个坐标系转换为另一个坐标系。您可以使用该方法指定要从哪个坐标系转换到哪个坐标系以及要转换到哪个坐标系。该方法需要满足以下条件:TransformByAlignCoordinateSystemAlignCoordinateSystem
将 OCS 坐标转换为 WCS 坐标本示例在模型空间中创建折线。然后,折线的第一个折点将同时显示在 OCS 和 WCS 坐标中。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("TranslateCoordinates")> _
Public Sub TranslateCoordinates()
'' Get the current document and database, and start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a 2D polyline with two segments (3 points)
Dim acPoly2d As Polyline2d = New Polyline2d()
acBlkTblRec.AppendEntity(acPoly2d)
acTrans.AddNewlyCreatedDBObject(acPoly2d, True)
'' Before adding vertexes, the polyline must be in the drawing
Dim acPts2dPoly As Point3dCollection = New Point3dCollection()
acPts2dPoly.Add(New Point3d(1, 1, 0))
acPts2dPoly.Add(New Point3d(1, 2, 0))
acPts2dPoly.Add(New Point3d(2, 2, 0))
acPts2dPoly.Add(New Point3d(3, 2, 0))
acPts2dPoly.Add(New Point3d(4, 4, 0))
For Each acPt3d As Point3d In acPts2dPoly
Dim acVer2d As Vertex2d = New Vertex2d(acPt3d, 0, 0, 0, 0)
acPoly2d.AppendVertex(acVer2d)
acTrans.AddNewlyCreatedDBObject(acVer2d, True)
Next
'' Set the normal of the 2D polyline
acPoly2d.Normal = New Vector3d(0, 1, 2)
'' Get the first coordinate of the 2D polyline
Dim acPts3d As Point3dCollection = New Point3dCollection()
Dim acFirstVer As Vertex2d = Nothing
For Each acObjIdVert As ObjectId In acPoly2d
acFirstVer = acTrans.GetObject(acObjIdVert, _
OpenMode.ForRead)
acPts3d.Add(acFirstVer.Position)
Exit For
Next
'' Get the first point of the polyline and
'' use the eleveation for the Z value
Dim pFirstVer As Point3d = New Point3d(acFirstVer.Position.X, _
acFirstVer.Position.Y, _
acPoly2d.Elevation)
'' Translate the OCS to WCS
Dim mWPlane As Matrix3d = Matrix3d.WorldToPlane(acPoly2d.Normal)
Dim pWCSPt As Point3d = pFirstVer.TransformBy(mWPlane)
Application.ShowAlertDialog("The first vertex has the following " & _
"coordinates:" & _
vbLf & "OCS: " + pFirstVer.ToString() & _
vbLf & "WCS: " + pWCSPt.ToString())
'' Save the new objects to the database
acTrans.Commit()
End Using
[CommandMethod("TranslateCoordinates")]
public static void TranslateCoordinates()
// Get the current document and database, and start a transaction
// Open the Block table record for read
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a 2D polyline with two segments (3 points)
using (Polyline2d acPoly2d = new Polyline2d())
acBlkTblRec.AppendEntity(acPoly2d);
acTrans.AddNewlyCreatedDBObject(acPoly2d, true);
// Before adding vertexes, the polyline must be in the drawing
Point3dCollection acPts2dPoly = new Point3dCollection();
acPts2dPoly.Add(new Point3d(1, 1, 0));
acPts2dPoly.Add(new Point3d(1, 2, 0));
acPts2dPoly.Add(new Point3d(2, 2, 0));
acPts2dPoly.Add(new Point3d(3, 2, 0));
acPts2dPoly.Add(new Point3d(4, 4, 0));
foreach (Point3d acPt3d in acPts2dPoly)
Vertex2d acVer2d = new Vertex2d(acPt3d, 0, 0, 0, 0);
acPoly2d.AppendVertex(acVer2d);
acTrans.AddNewlyCreatedDBObject(acVer2d, true);
// Set the normal of the 2D polyline
acPoly2d.Normal = new Vector3d(0, 1, 2);
// Get the first coordinate of the 2D polyline
Point3dCollection acPts3d = new Point3dCollection();
Vertex2d acFirstVer = null;
foreach (ObjectId acObjIdVert in acPoly2d)
OpenMode.ForRead) as Vertex2d;
acPts3d.Add(acFirstVer.Position);
break;
// Get the first point of the polyline and
// use the eleveation for the Z value
Point3d pFirstVer = new Point3d(acFirstVer.Position.X,
acPoly2d.Elevation);
// Translate the OCS to WCS
Matrix3d mWPlane = Matrix3d.WorldToPlane(acPoly2d.Normal);
Point3d pWCSPt = pFirstVer.TransformBy(mWPlane);
Application.ShowAlertDialog("The first vertex has the following " +
"coordinates:" +
"\nOCS: " + pFirstVer.ToString() +
"\nWCS: " + pWCSPt.ToString());
// Save the new objects to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub TranslateCoordinates()
' Create a polyline in model space.
Dim plineObj As AcadPolyline
Dim points(0 To 14) As Double
' Define the 2D polyline points
points(0) = 1: points(1) = 1: points(2) = 0
points(3) = 1: points(4) = 2: points(5) = 0
points(6) = 2: points(7) = 2: points(8) = 0
points(9) = 3: points(10) = 2: points(11) = 0
points(12) = 4: points(13) = 4: points(14) = 0
' Create a light weight Polyline object in model space
Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
' Find the X and Y coordinates of the
' first vertex of the polyline
Dim firstVertex As Variant
firstVertex = plineObj.Coordinate(0)
' Find the Z coordinate for the polyline
' using the elevation property
firstVertex(2) = plineObj.Elevation
' Change the normal for the pline so that the
' difference between the coordinate systems
' is obvious.
Dim plineNormal(0 To 2) As Double
plineNormal(0) = 0#
plineNormal(1) = 1#
plineNormal(2) = 2#
plineObj.Normal = plineNormal
' Translate the OCS coordinate into WCS
Dim coordinateWCS As Variant
coordinateWCS = ThisDrawing.Utility.TranslateCoordinates _
(firstVertex, acOCS, acWorld, False, plineNormal)
' Display the coordinates of the point
MsgBox "The first vertex has the following coordinates:" _
& vbCrLf & "OCS: (" & firstVertex(0) & "," & _
firstVertex(1) & "," & firstVertex(2) & ")" & vbCrLf & _
"WCS: (" & coordinateWCS(0) & "," & _
coordinateWCS(1) & "," & coordinateWCS(2) & ")"
相关概念父主题: |
GMT+8, 2026-10-28 01:43
