创建几何公差 (.NET)
2024-5-18 17:56| 发布者: admin| 查看: 784| 评论: 0|原作者: admin|来自: AutoCAD
创建几何公差 (.NET)
您可以通过创建对象的实例来创建几何公差。创建对象的实例时,其构造函数可以接受一组可选的参数。创建新对象时,可以提供以下参数:FeatureControlFrameFeatureControlFrameFeatureControlFrame
  • 包含公差符号(属性)的文本字符串Text
  • 插入点 ( 属性)Location
  • 法向量 ( 属性)Normal
  • 方向矢量 ( 属性)Direction
创建几何公差
此示例在模型空间中创建一个简单的几何公差。
VB.NET
<CommandMethod("CreateGeometricTolerance")> _
Public Sub CreateGeometricTolerance()
    '' Get the current database
    '' Start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create the Geometric Tolerance (Feature Control Frame)
        Using acFcf As FeatureControlFrame = New FeatureControlFrame()
            acFcf.Text = "{\Fgdt;j}%%v{\Fgdt;n}0.001%%v%%v%%v%%v"
            acFcf.Location = New Point3d(5, 5, 0)
            '' Add the new object to Model space and the transaction
            acBlkTblRec.AppendEntity(acFcf)
            acTrans.AddNewlyCreatedDBObject(acFcf, True)
        End Using
        '' Commit the changes and dispose of the transaction
        acTrans.Commit()
    End Using
C#
[CommandMethod("CreateGeometricTolerance")]
public static void CreateGeometricTolerance()
    // Get the current database
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create the Geometric Tolerance (Feature Control Frame)
        using (FeatureControlFrame acFcf = new FeatureControlFrame())
            acFcf.Text = "{\\Fgdt;j}%%v{\\Fgdt;n}0.001%%v%%v%%v%%v";
            acFcf.Location = new Point3d(5, 5, 0);
            // Add the new object to Model space and the transaction
            acBlkTblRec.AppendEntity(acFcf);
            acTrans.AddNewlyCreatedDBObject(acFcf, true);
        // Commit the changes and dispose of the transaction
        acTrans.Commit();
VBA/ActiveX 代码参考
    Dim toleranceObj As AcadTolerance
    Dim textString As String
    Dim direction(0 To 2) As Double
    ' Define the tolerance object
    textString = "{\Fgdt;j}%%v{\Fgdt;n}0.001%%v%%v%%v%%v"
    insertionPoint(0) = 5
    insertionPoint(1) = 5
    insertionPoint(2) = 0
    direction(0) = 1
    direction(1) = 0
    direction(2) = 0
    ' Create the tolerance object in model space
    Set toleranceObj = ThisDrawing.ModelSpace. _
                           AddTolerance(textString, insertionPoint, direction)
    ZoomAll
GMT+8, 2026-10-27 16:51
