创建周动半径尺寸 (.NET)
点动半径尺寸测量对象的半径,并在其前面显示带有半径符号的尺寸文本。在以下情况下,可以在径向尺寸对象上使用轨迹尺寸:
通过创建对象的实例来创建周动半径尺寸。创建对象的实例时,其构造函数可以选择接受设置的参数。创建新对象时,可以提供以下参数:RadialDimensionLargeRadialDimensionLargeRadialDimensionLarge
创建周动半径尺寸本示例在模型空间中创建角拐半径尺寸。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("CreateJoggedDimension")> _
Public Sub CreateJoggedDimension()
'' Get the current database
'' Start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a large radius dimension
Using acRadDimLrg As RadialDimensionLarge = New RadialDimensionLarge()
acRadDimLrg.Center = New Point3d(-3, -4, 0)
acRadDimLrg.ChordPoint = New Point3d(2, 7, 0)
acRadDimLrg.OverrideCenter = New Point3d(0, 2, 0)
acRadDimLrg.JogPoint = New Point3d(1, 4.5, 0)
acRadDimLrg.JogAngle = 0.707
acRadDimLrg.DimensionStyle = acCurDb.Dimstyle
'' Add the new object to Model space and the transaction
acBlkTblRec.AppendEntity(acRadDimLrg)
acTrans.AddNewlyCreatedDBObject(acRadDimLrg, True)
End Using
'' Commit the changes and dispose of the transaction
acTrans.Commit()
End Using
[CommandMethod("CreateJoggedDimension")]
public static void CreateJoggedDimension()
// Get the current database
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a large radius dimension
using (RadialDimensionLarge acRadDimLrg = new RadialDimensionLarge())
acRadDimLrg.Center = new Point3d(-3, -4, 0);
acRadDimLrg.ChordPoint = new Point3d(2, 7, 0);
acRadDimLrg.OverrideCenter = new Point3d(0, 2, 0);
acRadDimLrg.JogPoint = new Point3d(1, 4.5, 0);
acRadDimLrg.JogAngle = 0.707;
acRadDimLrg.DimensionStyle = acCurDb.Dimstyle;
// Add the new object to Model space and the transaction
acBlkTblRec.AppendEntity(acRadDimLrg);
acTrans.AddNewlyCreatedDBObject(acRadDimLrg, true);
// Commit the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub CreateJoggedDimension()
Dim dimObj As AcadDimRadialLarge
Dim chordPoint(0 To 2) As Double
Dim centerOverPoint(0 To 2) As Double
Dim jogPoint(0 To 2) As Double
Dim jogAngle As Double
' Define the dimension
centerPoint(0) = -3: centerPoint(1) = -4: centerPoint(2) = 0
chordPoint(0) = 2: chordPoint(1) = 7: chordPoint(2) = 0
centerOverPoint(0) = 0: centerOverPoint(1) = 2: centerOverPoint(2) = 0
jogPoint(0) = 1: jogPoint(1) = 4.5: jogPoint(2) = 0
jogAngle = 0.707
' Create the jogged dimension in Model space
Set dimObj = ThisDrawing.ModelSpace. _
AddDimRadialLarge(centerPoint, chordPoint, _
centerOverPoint, jogPoint, _
jogAngle)
ZoomAll
相关概念父主题: |
GMT+8, 2026-10-27 13:28
