创建角度维度 (.NET)
角度尺寸测量两条线或三点之间的角度。例如,您可以使用它们来测量圆的两个半径之间的角度。尺寸线形成一个圆弧。角度尺寸是通过创建 或 对象的实例来创建的。LineAngularDimension2Point3AngularDimension
创建 or 对象的实例时,构造函数可以选择接受设置参数。创建新对象时,可以提供以下参数:LineAngularDimension2Point3AngularDimensionLineAngularDimension2
创建新对象时,可以提供以下参数:Point3AngularDimension
创建角度维度本示例在模型空间中创建一个角度维度。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("CreateAngularDimension")> _
Public Sub CreateAngularDimension()
'' Get the current database
'' Start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
'' Create an angular dimension
Using acLinAngDim As LineAngularDimension2 = New LineAngularDimension2()
acLinAngDim.XLine1Start = New Point3d(0, 5, 0)
acLinAngDim.XLine1End = New Point3d(1, 7, 0)
acLinAngDim.XLine2Start = New Point3d(0, 5, 0)
acLinAngDim.XLine2End = New Point3d(1, 3, 0)
acLinAngDim.ArcPoint = New Point3d(3, 5, 0)
acLinAngDim.DimensionStyle = acCurDb.Dimstyle
'' Add the new object to Model space and the transaction
acBlkTblRec.AppendEntity(acLinAngDim)
acTrans.AddNewlyCreatedDBObject(acLinAngDim, True)
End Using
'' Commit the changes and dispose of the transaction
acTrans.Commit()
End Using
[CommandMethod("CreateAngularDimension")]
public static void CreateAngularDimension()
// Get the current database
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create an angular dimension
using (LineAngularDimension2 acLinAngDim = new LineAngularDimension2())
acLinAngDim.XLine1Start = new Point3d(0, 5, 0);
acLinAngDim.XLine1End = new Point3d(1, 7, 0);
acLinAngDim.XLine2Start = new Point3d(0, 5, 0);
acLinAngDim.XLine2End = new Point3d(1, 3, 0);
acLinAngDim.ArcPoint = new Point3d(3, 5, 0);
acLinAngDim.DimensionStyle = acCurDb.Dimstyle;
// Add the new object to Model space and the transaction
acBlkTblRec.AppendEntity(acLinAngDim);
acTrans.AddNewlyCreatedDBObject(acLinAngDim, true);
// Commit the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub CreateAngularDimension()
Dim dimObj As AcadDimAngular
Dim angVert(0 To 2) As Double
Dim FirstPoint(0 To 2) As Double
Dim SecondPoint(0 To 2) As Double
Dim TextPoint(0 To 2) As Double
' Define the dimension
angVert(0) = 0
angVert(1) = 5
angVert(2) = 0
FirstPoint(0) = 1
FirstPoint(1) = 7
FirstPoint(2) = 0
SecondPoint(0) = 1
SecondPoint(1) = 3
SecondPoint(2) = 0
TextPoint(0) = 3
TextPoint(1) = 5
TextPoint(2) = 0
' Create the angular dimension in model space
Set dimObj = ThisDrawing.ModelSpace. _
AddDimAngular(angVert, FirstPoint, SecondPoint, TextPoint)
ZoomAll
相关概念父主题: |
GMT+8, 2026-10-26 13:49
