对齐单行文本 (.NET)
您可以水平和垂直对齐单行文本。左对齐是默认设置。若要设置水平和垂直对齐选项,请使用 和 属性。HorizontalModeVerticalMode 通常,当文本对象关闭时,会根据其对齐方式和文本样式调整文本对象的位置和对齐点。但是,内存中文本对象的对齐方式不会自动更新。调用该方法以根据文本对象的当前属性值更新其对齐方式。AdjustAlignment 重新对齐文本下面的示例创建一个单行文本 () 对象和一个点 () 对象。点对象设置为文本对齐点,并更改为红色十字准线,以便可见。更改文本对齐方式并显示一个消息框,以便停止宏执行。这使您可以查看更改文本对齐方式的影响。DBTextDBPoint VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("TextAlignment")> _
Public Sub TextAlignment()
'' Start a transaction
Dim acBlkTbl As BlockTable
OpenMode.ForRead)
OpenMode.ForWrite)
Dim textString(0 To 2) As String
textString(0) = "Left"
textString(1) = "Center"
textString(2) = "Right"
Dim textAlign(0 To 2) As Integer
textAlign(0) = TextHorizontalMode.TextLeft
textAlign(1) = TextHorizontalMode.TextCenter
textAlign(2) = TextHorizontalMode.TextRight
Dim acPtIns As Point3d = New Point3d(3, 3, 0)
Dim acPtAlign As Point3d = New Point3d(3, 3, 0)
Dim nCnt As Integer = 0
For Each strVal As String In textString
'' Create a single-line text object
Using acText As DBText = New DBText()
acText.Position = acPtIns
acText.Height = 0.5
acText.TextString = strVal
'' Set the alignment for the text
acText.HorizontalMode = textAlign(nCnt)
If acText.HorizontalMode <> TextHorizontalMode.TextLeft Then
acText.AlignmentPoint = acPtAlign
End If
acBlkTblRec.AppendEntity(acText)
acTrans.AddNewlyCreatedDBObject(acText, True)
End Using
'' Create a point over the alignment point of the text
Using acPoint As DBPoint = New DBPoint(acPtAlign)
acPoint.ColorIndex = 1
acBlkTblRec.AppendEntity(acPoint)
acTrans.AddNewlyCreatedDBObject(acPoint, True)
'' Adjust the insertion and alignment points
acPtIns = New Point3d(acPtIns.X, acPtIns.Y + 3, 0)
acPtAlign = acPtIns
End Using
nCnt = nCnt + 1
Next
'' Set the point style to crosshair
Application.SetSystemVariable("PDMODE", 2)
'' Save the changes and dispose of the transaction
acTrans.Commit()
End Using
[CommandMethod("TextAlignment")]
public static void TextAlignment()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
string[] textString = new string[3];
textString[0] = "Left";
textString[1] = "Center";
textString[2] = "Right";
int[] textAlign = new int[3];
textAlign[0] = (int)TextHorizontalMode.TextLeft;
textAlign[1] = (int)TextHorizontalMode.TextCenter;
textAlign[2] = (int)TextHorizontalMode.TextRight;
Point3d acPtIns = new Point3d(3, 3, 0);
Point3d acPtAlign = new Point3d(3, 3, 0);
int nCnt = 0;
foreach (string strVal in textString)
// Create a single-line text object
using (DBText acText = new DBText())
acText.Position = acPtIns;
acText.Height = 0.5;
acText.TextString = strVal;
// Set the alignment for the text
acText.HorizontalMode = (TextHorizontalMode)textAlign[nCnt];
if (acText.HorizontalMode != TextHorizontalMode.TextLeft)
acText.AlignmentPoint = acPtAlign;
acBlkTblRec.AppendEntity(acText);
acTrans.AddNewlyCreatedDBObject(acText, true);
// Create a point over the alignment point of the text
using (DBPoint acPoint = new DBPoint(acPtAlign))
acPoint.ColorIndex = 1;
acBlkTblRec.AppendEntity(acPoint);
acTrans.AddNewlyCreatedDBObject(acPoint, true);
// Adjust the insertion and alignment points
acPtIns = new Point3d(acPtIns.X, acPtIns.Y + 3, 0);
acPtAlign = acPtIns;
nCnt = nCnt + 1;
// Set the point style to crosshair
Application.SetSystemVariable("PDMODE", 2);
// Save the changes and dispose of the transaction
acTrans.Commit();
VBA/ActiveX 代码参考Sub TextAlignment()
ThisDrawing.SetVariable "PDMODE", 2
Dim textObj As AcadText
Dim pointObj As AcadPoint
' Define the text strings and insertion point for the text objects
textAlign(0) = acAlignmentLeft
textAlign(1) = acAlignmentCenter
textAlign(2) = acAlignmentRight
insertionPoint(0) = 3: insertionPoint(1) = 0: insertionPoint(2) = 0
Dim alignmentPoint(0 To 2) As Double
alignmentPoint(0) = 3: alignmentPoint(1) = 0: alignmentPoint(2) = 0
Dim nCnt As Integer
For Each strVal In textString
' Create the Text object in model space
Set textObj = ThisDrawing.ModelSpace. _
AddText(strVal, insertionPoint, 0.5)
textObj.Alignment = textAlign(nCnt)
On Error Resume Next
textObj.TextAlignmentPoint = alignmentPoint
Set pointObj = ThisDrawing.ModelSpace.AddPoint(alignmentPoint)
pointObj.color = acRed
insertionPoint(1) = insertionPoint(1) + 3
alignmentPoint(1) = insertionPoint(1)
nCnt = nCnt + 1
Next
相关概念父主题: |
GMT+8, 2026-10-27 21:25
