删除图层状态 (.NET)
2024-5-18 17:56| 发布者: admin| 查看: 750| 评论: 0|原作者: admin|来自: AutoCAD
删除图层状态 (.NET)
该方法从图形中移除保存的图层状态。以下代码将删除以 ColorLinetype 名称保存的图层状态。DeleteLayerState
VB.NET
<CommandMethod("RemoveLayerState")> _
Public Sub RemoveLayerState()
    '' Get the current document
    Dim acLyrStMan As LayerStateManager
    acLyrStMan = acDoc.Database.LayerStateManager
    Dim sLyrStName As String = "ColorLinetype"
    If acLyrStMan.HasLayerState(sLyrStName) = True Then
        acLyrStMan.DeleteLayerState(sLyrStName)
    End If
C#
[CommandMethod("RemoveLayerState")]
public static void RemoveLayerState()
    // Get the current document
    LayerStateManager acLyrStMan;
    acLyrStMan = acDoc.Database.LayerStateManager;
    string sLyrStName = "ColorLinetype";
    if (acLyrStMan.HasLayerState(sLyrStName) == true)
        acLyrStMan.DeleteLayerState(sLyrStName);
VBA/ActiveX 代码参考
    Dim oLSM As AcadLayerStateManager
    Set oLSM = ThisDrawing.Application. _
                   GetInterfaceObject("AutoCAD.AcadLayerStateManager.23")
    oLSM.SetDatabase ThisDrawing.Database
    oLSM.Delete "ColorLinetype"
GMT+8, 2026-10-28 03:57
