使线型在数据库中成为当前 (.NET)
2024-5-18 17:56| 发布者: admin| 查看: 709| 评论: 0|原作者: admin|来自: AutoCAD
使线型在数据库中成为当前 (.NET)
本示例使用属性设置通过对象的线型电流。DatabaseCeltype
VB.NET
<CommandMethod("SetLinetypeCurrent")> _
Public Sub SetLinetypeCurrent()
    '' Start a transaction
        '' Open the Linetype table for read
        Dim acLineTypTbl As LinetypeTable
        acLineTypTbl = acTrans.GetObject(acCurDb.LinetypeTableId, _
                                         OpenMode.ForRead)
        Dim sLineTypName As String = "Center"
        If acLineTypTbl.Has(sLineTypName) = True Then
            '' Set the linetype Center current
            acCurDb.Celtype = acLineTypTbl(sLineTypName)
            '' Save the changes
            acTrans.Commit()
        End If
        '' Dispose of the transaction
    End Using
C#
[CommandMethod("SetLinetypeCurrent")]
public static void SetLinetypeCurrent()
    // Start a transaction
        // Open the Linetype table for read
        LinetypeTable acLineTypTbl;
                                            OpenMode.ForRead) as LinetypeTable;
        string sLineTypName = "Center";
        if (acLineTypTbl.Has(sLineTypName) == true)
            // Set the linetype Center current
            acCurDb.Celtype = acLineTypTbl[sLineTypName];
            // Save the changes
            acTrans.Commit();
        // Dispose of the transaction
VBA/ActiveX 代码参考
ThisDrawing.ActiveLinetype = ThisDrawing.Linetypes.Item("Center")
GMT+8, 2026-10-26 18:22
