创建极坐标阵列 (.NET)
2024-5-18 17:56| 发布者: admin| 查看: 582| 评论: 0|原作者: admin|来自: AutoCAD
创建极坐标阵列 (.NET)
此示例创建一个圆,然后执行该圆的极坐标数组。这将创建四个圆,围绕基点 (4, 4, 0) 填充 180 度。
VB.NET
Public Shared Function PolarPoints(ByVal pPt As Point2d, _
                                   ByVal dAng As Double, _
                                   ByVal dDist As Double)
  Return New Point2d(pPt.X + dDist * Math.Cos(dAng), _
                     pPt.Y + dDist * Math.Sin(dAng))
End Function
<CommandMethod("PolarArrayObject")> _
Public Sub PolarArrayObject()
    '' Start a transaction
        '' Open the Block table record for read
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a circle that is at 2,2 with a radius of 1
        Using acCirc As Circle = New Circle()
            acCirc.Center = New Point3d(2, 2, 0)
            acCirc.Radius = 1
            acBlkTblRec.AppendEntity(acCirc)
            acTrans.AddNewlyCreatedDBObject(acCirc, True)
            '' Create a 4 object polar array that goes a 180
            Dim nCount As Integer = 1
            '' Set a value in radians for 60 degrees
            Dim dAng As Double = 1.0472
            '' Use (4,4,0) as the base point for the array
            Dim acPt2dArrayBase As Point2d = New Point2d(4, 4)
            While (nCount < 4)
                Dim acEntClone As Entity = acCirc.Clone()
                Dim acExts As Extents3d
                Dim acPtObjBase As Point2d
                '' Typically the upper-left corner of an object's extents is used
                '' for the point on the object to be arrayed unless it is
                '' an object like a circle.
                Dim acCircArrObj As Circle = acEntClone
                If IsDBNull(acCircArrObj) = False Then
                     acPtObjBase = New Point2d(acCircArrObj.Center.X, _
                                               acCircArrObj.Center.Y)
                Else
                     acExts = acEntClone.Bounds.GetValueOrDefault()
                     acPtObjBase = New Point2d(acExts.MinPoint.X, _
                                               acExts.MaxPoint.Y)
                End If
                Dim dDist As Double = acPt2dArrayBase.GetDistanceTo(acPtObjBase)
                Dim dAngFromX As Double = acPt2dArrayBase.GetVectorTo(acPtObjBase).Angle
                Dim acPt2dTo As Point2d = PolarPoints(acPt2dArrayBase, _
                                                      (nCount * dAng) + dAngFromX, _
                                                      dDist)
                Dim acVec2d As Vector2d = acPtObjBase.GetVectorTo(acPt2dTo)
                Dim acVec3d As Vector3d = New Vector3d(acVec2d.X, acVec2d.Y, 0)
                acEntClone.TransformBy(Matrix3d.Displacement(acVec3d))
                '' The following code demonstrates how to rotate each object like
                '' the ARRAY command does.
                'acExts = acEntClone.Bounds.GetValueOrDefault()
                'acPtObjBase = New Point2d(acExts.MinPoint.X, _
                '                          acExts.MaxPoint.Y)
                '' Rotate the cloned entity and around its upper-left extents point
                'Dim curUCSMatrix As Matrix3d = acDoc.Editor.CurrentUserCoordinateSystem
                'Dim curUCS As CoordinateSystem3d = curUCSMatrix.CoordinateSystem3d
                'acEntClone.TransformBy(Matrix3d.Rotation(nCount * dAng, _
                '                                         curUCS.Zaxis, _
                '                                         New Point3d(acPtObjBase.X, _
                '                                                     acPtObjBase.Y, 0)))
                acBlkTblRec.AppendEntity(acEntClone)
                acTrans.AddNewlyCreatedDBObject(acEntClone, True)
                nCount = nCount + 1
            End While
        End Using
        '' Save the new objects to the database
        acTrans.Commit()
    End Using
C#
static Point2d PolarPoints(Point2d pPt, double dAng, double dDist)
  return new Point2d(pPt.X + dDist * Math.Cos(dAng),
                     pPt.Y + dDist * Math.Sin(dAng));
[CommandMethod("PolarArrayObject")]
public static void PolarArrayObject()
    // Start a transaction
        // Open the Block table record for read
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a circle that is at 2,2 with a radius of 1
        using (Circle acCirc = new Circle())
            acCirc.Center = new Point3d(2, 2, 0);
            acCirc.Radius = 1;
            acBlkTblRec.AppendEntity(acCirc);
            acTrans.AddNewlyCreatedDBObject(acCirc, true);
            // Create a 4 object polar array that goes a 180
            int nCount = 1;
            // Set a value in radians for 60 degrees
            double dAng = 1.0472;
            // Use (4,4,0) as the base point for the array
            Point2d acPt2dArrayBase = new Point2d(4, 4);
            while (nCount < 4)
                Entity acEntClone = acCirc.Clone() as Entity;
                Extents3d acExts;
                Point2d acPtObjBase;
                // Typically the upper-left corner of an object's extents is used
                // for the point on the object to be arrayed unless it is
                // an object like a circle.
                Circle acCircArrObj = acEntClone as Circle;
                if (acCircArrObj != null)
                    acPtObjBase = new Point2d(acCircArrObj.Center.X,
                                                acCircArrObj.Center.Y);
                else
                    acExts = acEntClone.Bounds.GetValueOrDefault();
                    acPtObjBase = new Point2d(acExts.MinPoint.X,
                                                acExts.MaxPoint.Y);
                double dDist = acPt2dArrayBase.GetDistanceTo(acPtObjBase);
                double dAngFromX = acPt2dArrayBase.GetVectorTo(acPtObjBase).Angle;
                Point2d acPt2dTo = PolarPoints(acPt2dArrayBase,
                                                dDist);
                Vector2d acVec2d = acPtObjBase.GetVectorTo(acPt2dTo);
                Vector3d acVec3d = new Vector3d(acVec2d.X, acVec2d.Y, 0);
                acEntClone.TransformBy(Matrix3d.Displacement(acVec3d));
                // The following code demonstrates how to rotate each object like
                // the ARRAY command does.
                                            acExts.MaxPoint.Y);
                // Rotate the cloned entity around its upper-left extents point
                Matrix3d curUCSMatrix = acDoc.Editor.CurrentUserCoordinateSystem;
                CoordinateSystem3d curUCS = curUCSMatrix.CoordinateSystem3d;
                                                            curUCS.Zaxis,
                                                            new Point3d(acPtObjBase.X,
        acPtObjBase.Y, 0)));
                acBlkTblRec.AppendEntity(acEntClone);
                acTrans.AddNewlyCreatedDBObject(acEntClone, true);
                nCount = nCount + 1;
        // Save the new objects to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
    ' Create the circle
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 2#: center(1) = 2#: center(2) = 0#
    radius = 1
    Set circleObj = ThisDrawing.ModelSpace. _
                                  AddCircle(center, radius)
    ZoomAll
    ' Define the polar array
    Dim noOfObjects As Integer
    Dim angleToFill As Double
    Dim basePnt(0 To 2) As Double
    noOfObjects = 4
    angleToFill = 3.14          ' 180 degrees
    basePnt(0) = 4#: basePnt(1) = 4#: basePnt(2) = 0#
    ' The following example will create 4 copies
    ' of an object by rotating and copying it about
    ' the point (4,4,0).
    Dim retObj As Variant
    retObj = circleObj.ArrayPolar _
                         (noOfObjects, angleToFill, basePnt)
    ZoomAll
GMT+8, 2026-10-27 14:22
