移动对象 (.NET)
2024-5-18 17:56| 发布者: admin| 查看: 714| 评论: 0|原作者: admin|来自: AutoCAD
移动对象 (.NET)
可以沿指定矢量移动所有图形对象和属性参照对象。
若要移动对象,请使用变换矩阵的函数。此函数需要一个对象作为输入。如果不知道所需的向量,可以创建一个对象,然后使用该方法返回两点之间的向量。位移矢量指示给定对象要移动多远以及向哪个方向移动。DisplacementVector3dPoint3dGetVectorTo
沿矢量移动圆圈
本示例创建一个圆,然后沿 X 轴移动该圆两个单位。
VB.NET
<CommandMethod("MoveObject")> _
Public Sub MoveObject()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
                                     OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a circle that is at 2,2 with a radius of 0.5
        Using acCirc As Circle = New Circle()
            acCirc.Center = New Point3d(2, 2, 0)
            acCirc.Radius = 0.5
            '' Create a matrix and move the circle using a vector from (0,0,0) to (2,0,0)
            Dim acPt3d As Point3d = New Point3d(0, 0, 0)
            Dim acVec3d As Vector3d = acPt3d.GetVectorTo(New Point3d(2, 0, 0))
            acCirc.TransformBy(Matrix3d.Displacement(acVec3d))
            acBlkTblRec.AppendEntity(acCirc)
            acTrans.AddNewlyCreatedDBObject(acCirc, True)
        End Using
        '' Save the new objects to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("MoveObject")]
public static void MoveObject()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a circle that is at 2,2 with a radius of 0.5
        using (Circle acCirc = new Circle())
            acCirc.Center = new Point3d(2, 2, 0);
            acCirc.Radius = 0.5;
            // Create a matrix and move the circle using a vector from (0,0,0) to (2,0,0)
            Point3d acPt3d = new Point3d(0, 0, 0);
            Vector3d acVec3d = acPt3d.GetVectorTo(new Point3d(2, 0, 0));
            acCirc.TransformBy(Matrix3d.Displacement(acVec3d));
            acBlkTblRec.AppendEntity(acCirc);
            acTrans.AddNewlyCreatedDBObject(acCirc, true);
        // Save the new objects to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub MoveObject()
    ' Create the circle
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 2#: center(1) = 2#: center(2) = 0#
    radius = 0.5
    Set circleObj = ThisDrawing.ModelSpace. _
                                  AddCircle(center, radius)
    ZoomAll
    ' Define the points that make up the move vector.
    ' The move vector will move the circle 2 units
    ' along the x axis.
    Dim point1(0 To 2) As Double
    Dim point2(0 To 2) As Double
    point1(0) = 0: point1(1) = 0: point1(2) = 0
    point2(0) = 2: point2(1) = 0: point2(2) = 0
    ' Move the circle
    circleObj.Move point1, point2
    circleObj.Update
GMT+8, 2026-10-27 14:27
