在数据库之间复制对象 (.NET)
您可以在两个数据库之间复制对象。该函数用于复制同一数据库中的对象,而该方法用于将对象从一个数据库复制到另一个数据库。该方法是对象的成员。该方法需要以下参数:CloneWblockCloneObjectsWblockCloneObjectsDatabaseWblockCloneObjects
将对象从一个数据库复制到另一个数据库本示例创建两个 Circle 对象,然后使用该方法将圆复制到新图形中。该示例还在复制圆之前使用 acad.dwt 文件创建新图形。WblockCloneObjects VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("CopyObjectsBetweenDatabases", CommandFlags.Session)> _
Public Sub CopyObjectsBetweenDatabases()
Dim acObjIdColl As ObjectIdCollection = New ObjectIdCollection()
'' Lock the current document
Using acLckDocCur As DocumentLock = acDoc.LockDocument()
'' Start a transaction
Dim acBlkTbl As BlockTable
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
OpenMode.ForWrite)
'' Create a circle that is at (0,0,0) with a radius of 5
Using acCirc1 As Circle = New Circle()
acCirc1.Center = New Point3d(0, 0, 0)
acCirc1.Radius = 5
acBlkTblRec.AppendEntity(acCirc1)
acTrans.AddNewlyCreatedDBObject(acCirc1, True)
'' Create a circle that is at (0,0,0) with a radius of 7
Using acCirc2 As Circle = New Circle()
acCirc2.Center = New Point3d(0, 0, 0)
acCirc2.Radius = 7
acBlkTblRec.AppendEntity(acCirc2)
acTrans.AddNewlyCreatedDBObject(acCirc2, True)
'' Add all the objects to copy to the new document
acObjIdColl = New ObjectIdCollection()
acObjIdColl.Add(acCirc1.ObjectId)
acObjIdColl.Add(acCirc2.ObjectId)
End Using
End Using
'' Save the new objects to the database
acTrans.Commit()
End Using
'' Unlock the document
End Using
'' Change the file and path to match a drawing template on your workstation
Dim sLocalRoot As String = Application.GetSystemVariable("LOCALROOTPREFIX")
Dim sTemplatePath As String = sLocalRoot + "Template\acad.dwt"
'' Create a new drawing to copy the objects to
Dim acDocMgr As DocumentCollection = Application.DocumentManager
Dim acNewDoc As Document = DocumentCollectionExtension.Add(acDocMgr, sTemplatePath)
Dim acDbNewDoc As Database = acNewDoc.Database
'' Lock the new document
Using acLckDoc As DocumentLock = acNewDoc.LockDocument()
'' Start a transaction in the new database
Using acTrans = acDbNewDoc.TransactionManager.StartTransaction()
Dim acBlkTblNewDoc As BlockTable
acBlkTblNewDoc = acTrans.GetObject(acDbNewDoc.BlockTableId, _
OpenMode.ForRead)
'' Open the Block table record Model space for read
Dim acBlkTblRecNewDoc As BlockTableRecord
acBlkTblRecNewDoc = acTrans.GetObject(acBlkTblNewDoc(BlockTableRecord.ModelSpace), _
OpenMode.ForRead)
'' Clone the objects to the new database
Dim acIdMap As IdMapping = New IdMapping()
acCurDb.WblockCloneObjects(acObjIdColl, acBlkTblRecNewDoc.ObjectId, acIdMap, _
DuplicateRecordCloning.Ignore, False)
'' Save the copied objects to the database
acTrans.Commit()
End Using
End Using
'' Set the new document current
acDocMgr.MdiActiveDocument = acNewDoc
[CommandMethod("CopyObjectsBetweenDatabases", CommandFlags.Session)]
public static void CopyObjectsBetweenDatabases()
ObjectIdCollection acObjIdColl = new ObjectIdCollection();
// Lock the current document
using (DocumentLock acLckDocCur = acDoc.LockDocument())
// Start a transaction
// Open the Block table record for read
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create a circle that is at (0,0,0) with a radius of 5
using (Circle acCirc1 = new Circle())
acCirc1.Center = new Point3d(0, 0, 0);
acCirc1.Radius = 5;
acBlkTblRec.AppendEntity(acCirc1);
acTrans.AddNewlyCreatedDBObject(acCirc1, true);
// Create a circle that is at (0,0,0) with a radius of 7
using (Circle acCirc2 = new Circle())
acCirc2.Center = new Point3d(0, 0, 0);
acCirc2.Radius = 7;
acBlkTblRec.AppendEntity(acCirc2);
acTrans.AddNewlyCreatedDBObject(acCirc2, true);
// Add all the objects to copy to the new document
acObjIdColl.Add(acCirc1.ObjectId);
acObjIdColl.Add(acCirc2.ObjectId);
// Save the new objects to the database
acTrans.Commit();
// Unlock the document
// Change the file and path to match a drawing template on your workstation
string sLocalRoot = Application.GetSystemVariable("LOCALROOTPREFIX") as string;
string sTemplatePath = sLocalRoot + "Template\\acad.dwt";
// Create a new drawing to copy the objects to
DocumentCollection acDocMgr = Application.DocumentManager;
Document acNewDoc = acDocMgr.Add(sTemplatePath);
Database acDbNewDoc = acNewDoc.Database;
// Lock the new document
using (DocumentLock acLckDoc = acNewDoc.LockDocument())
// Start a transaction in the new database
using (Transaction acTrans = acDbNewDoc.TransactionManager.StartTransaction())
BlockTable acBlkTblNewDoc;
// Open the Block table record Model space for read
BlockTableRecord acBlkTblRecNewDoc;
acBlkTblRecNewDoc = acTrans.GetObject(acBlkTblNewDoc[BlockTableRecord.ModelSpace],
OpenMode.ForRead) as BlockTableRecord;
// Clone the objects to the new database
IdMapping acIdMap = new IdMapping();
DuplicateRecordCloning.Ignore, false);
// Save the copied objects to the database
acTrans.Commit();
// Set the new document current
acDocMgr.MdiActiveDocument = acNewDoc;
VBA/ActiveX 代码参考Sub CopyObjectsBetweenDatabases()
Dim DOC0 As AcadDocument
Dim circleObj1 As AcadCircle, circleObj2 As AcadCircle
Dim radius1 As Double, radius2 As Double
Dim objCollection(0 To 1) As Object
Dim retObjects As Variant
' Define the Circle object
centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
radius1 = 5#: radius2 = 7#
' Add two circles to the current drawing
Set circleObj1 = ThisDrawing.ModelSpace.AddCircle _
(centerPoint, radius1)
Set circleObj2 = ThisDrawing.ModelSpace.AddCircle _
(centerPoint, radius2)
' Save pointer to the current drawing
Set DOC0 = ThisDrawing.Application.ActiveDocument
' Copy objects
' First put the objects to be copied into a form compatible
' with CopyObjects
Set objCollection(0) = circleObj1
Set objCollection(1) = circleObj2
' Create a new drawing and point to its model space
Dim Doc1MSpace As AcadModelSpace
Dim DOC1 As AcadDocument
Set DOC1 = Documents.Add
Set Doc1MSpace = DOC1.ModelSpace
' Copy the objects into the model space of the new drawing. A
' collection of the new (copied) objects is returned.
retObjects = DOC0.CopyObjects(objCollection, Doc1MSpace)
相关概念父主题: |
GMT+8, 2026-10-26 13:47
