在选择筛选器中指定多个条件 (.NET)
2024-5-18 17:56| 发布者: admin| 查看: 703| 评论: 0|原作者: admin|来自: AutoCAD
选择筛选器可以包含多个属性或对象的筛选条件。您可以通过声明一个包含足够元素来表示每个筛选条件的数组来定义要筛选的条件总数。
选择满足两个条件的对象
以下示例指定用于筛选所选对象的两个条件:对象必须是圆形,并且必须位于图层 0 上。
VB.NET
Imports Autodesk.AutoCAD.EditorInput
<CommandMethod("FilterBlueCircleOnLayer0")> _
Public Sub FilterBlueCircleOnLayer0()
    '' Get the current document editor
    Dim acDocEd As Editor = Application.DocumentManager.MdiActiveDocument.Editor
    '' Create a TypedValue array to define the filter criteria
    Dim acTypValAr(2) As TypedValue
    acTypValAr.SetValue(New TypedValue(DxfCode.Color, 5), 0)
    acTypValAr.SetValue(New TypedValue(DxfCode.Start, "CIRCLE"), 1)
    acTypValAr.SetValue(New TypedValue(DxfCode.LayerName, "0"), 2)
    '' Assign the filter criteria to a SelectionFilter object
    Dim acSelFtr As SelectionFilter = New SelectionFilter(acTypValAr)
    '' Request for objects to be selected in the drawing area
    Dim acSSPrompt As PromptSelectionResult
    acSSPrompt = acDocEd.GetSelection(acSelFtr)
    '' If the prompt status is OK, objects were selected
    If acSSPrompt.Status = PromptStatus.OK Then
        Dim acSSet As SelectionSet = acSSPrompt.Value
        Application.ShowAlertDialog("Number of objects selected: " & _
                                    acSSet.Count.ToString())
    Else
        Application.ShowAlertDialog("Number of objects selected: 0")
    End If
C#
using Autodesk.AutoCAD.EditorInput;
[CommandMethod("FilterBlueCircleOnLayer0")]
public static void FilterBlueCircleOnLayer0()
    // Get the current document editor
    Editor acDocEd = Application.DocumentManager.MdiActiveDocument.Editor;
    // Create a TypedValue array to define the filter criteria
    TypedValue[] acTypValAr = new TypedValue[3];
    acTypValAr.SetValue(new TypedValue((int)DxfCode.Color, 5), 0);
    acTypValAr.SetValue(new TypedValue((int)DxfCode.Start, "CIRCLE"), 1);
    acTypValAr.SetValue(new TypedValue((int)DxfCode.LayerName, "0"), 2);
    // Assign the filter criteria to a SelectionFilter object
    SelectionFilter acSelFtr = new SelectionFilter(acTypValAr);
    // Request for objects to be selected in the drawing area
    PromptSelectionResult acSSPrompt;
    acSSPrompt = acDocEd.GetSelection(acSelFtr);
    // If the prompt status is OK, objects were selected
    if (acSSPrompt.Status == PromptStatus.OK)
        SelectionSet acSSet = acSSPrompt.Value;
        Application.ShowAlertDialog("Number of objects selected: " +
                                    acSSet.Count.ToString());
    else
        Application.ShowAlertDialog("Number of objects selected: 0");
VBA/ActiveX 代码参考
    Dim sset As AcadSelectionSet
    Set sset = ThisDrawing.SelectionSets.Add("SS1")
    ' Define the filter list, only blue Circle objects
    ' on layer 0
    Dim FilterType(2) As Integer
    Dim FilterData(2) As Variant
    FilterType(0) = 62: FilterData(0) = 3
    FilterType(1) = 0: FilterData(1) = "Circle"
    FilterType(2) = 8: FilterData(2) = "0"
    ' Prompt the user to select objects
    ' and add them to the selection set
    sset.SelectOnScreen FilterType, FilterData
    MsgBox "Number of objects selected: " & sset.Count
    ' Remove the selection set at the end
    sset.Delete
GMT+8, 2026-10-26 12:59
