创建复合区域 (.NET)
您可以通过减去、合并或查找区域或 3D 实体的交点来创建复合区域。然后,可以拉伸或旋转复合区域以创建复杂的实体。若要创建复合区域,请使用以下方法。BooleanOperation 减去区域当您从一个区域中减去另一个区域时,您可以从第一个区域调用该方法。这是要从中减去的区域。例如,若要计算楼层平面图需要多少地毯,请从楼层空间的外部边界调用该方法,并将未铺设地毯的区域(如柱子和柜台)用作布尔参数列表中的对象。BooleanOperationBooleanOperation 联合区域若要统一区域,请调用该方法并使用常量进行操作,而不是 。您可以按任意顺序组合区域以统一它们。BooleanOperationBooleanOperationType.BoolUniteBooleanOperationType.BoolSubtract 查找两个区域的交集若要查找两个区域的交集,请使用常量 。您可以按任意顺序组合区域以与它们相交。BooleanOperationType.BoolIntersect 创建复合区域下面的示例从两个圆中创建两个区域,然后从大圆中减去较小的区域以创建一个轮子。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("CreateCompositeRegions")> _
Public Sub CreateCompositeRegions()
'' Start a transaction
Dim acBlkTbl As BlockTable
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
OpenMode.ForWrite)
'' Create two in memory circles
Using acCirc1 As Circle = New Circle()
acCirc1.Center = New Point3d(4, 4, 0)
acCirc1.Radius = 2
Using acCirc2 As Circle = New Circle()
acCirc2.Center = New Point3d(4, 4, 0)
acCirc2.Radius = 1
'' Adds the circle to an object array
Dim acDBObjColl As DBObjectCollection = New DBObjectCollection()
acDBObjColl.Add(acCirc1)
acDBObjColl.Add(acCirc2)
'' Calculate the regions based on each closed loop
Dim myRegionColl As DBObjectCollection = New DBObjectCollection()
myRegionColl = Region.CreateFromCurves(acDBObjColl)
Dim acRegion1 As Region = myRegionColl(0)
Dim acRegion2 As Region = myRegionColl(1)
'' Subtract region 1 from region 2
If acRegion1.Area > acRegion2.Area Then
'' Subtract the smaller region from the larger one
acRegion1.BooleanOperation(BooleanOperationType.BoolSubtract, acRegion2)
acRegion2.Dispose()
'' Add the final region to the database
acBlkTblRec.AppendEntity(acRegion1)
acTrans.AddNewlyCreatedDBObject(acRegion1, True)
Else
acRegion2.BooleanOperation(BooleanOperationType.BoolSubtract, acRegion1)
acRegion1.Dispose()
acBlkTblRec.AppendEntity(acRegion2)
acTrans.AddNewlyCreatedDBObject(acRegion2, True)
End If
'' Dispose of the in memory objects not appended to the database
End Using
End Using
'' Save the new object to the database
acTrans.Commit()
End Using
[CommandMethod("CreateCompositeRegions")]
public static void CreateCompositeRegions()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create two in memory circles
using (Circle acCirc1 = new Circle())
acCirc1.Center = new Point3d(4, 4, 0);
acCirc1.Radius = 2;
using (Circle acCirc2 = new Circle())
acCirc2.Center = new Point3d(4, 4, 0);
acCirc2.Radius = 1;
// Adds the circle to an object array
DBObjectCollection acDBObjColl = new DBObjectCollection();
acDBObjColl.Add(acCirc1);
acDBObjColl.Add(acCirc2);
// Calculate the regions based on each closed loop
DBObjectCollection myRegionColl = new DBObjectCollection();
myRegionColl = Region.CreateFromCurves(acDBObjColl);
Region acRegion1 = myRegionColl[0] as Region;
Region acRegion2 = myRegionColl[1] as Region;
// Subtract region 1 from region 2
if (acRegion1.Area > acRegion2.Area)
// Subtract the smaller region from the larger one
acRegion1.BooleanOperation(BooleanOperationType.BoolSubtract, acRegion2);
acRegion2.Dispose();
// Add the final region to the database
acBlkTblRec.AppendEntity(acRegion1);
acTrans.AddNewlyCreatedDBObject(acRegion1, true);
else
acRegion2.BooleanOperation(BooleanOperationType.BoolSubtract, acRegion1);
acRegion1.Dispose();
acBlkTblRec.AppendEntity(acRegion2);
acTrans.AddNewlyCreatedDBObject(acRegion2, true);
// Dispose of the in memory objects not appended to the database
// Save the new object to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub CreateCompositeRegions()
' Create two circles, one representing outside of the wheel,
' the other the center of the wheel
Dim DonutParts(0 To 1) As AcadCircle
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 4
center(1) = 4
center(2) = 0
radius = 2#
Set WheelParts(0) = ThisDrawing.ModelSpace. _
AddCircle(center, radius)
radius = 1#
Set WheelParts(1) = ThisDrawing.ModelSpace. _
' Create a region from the two circles
Dim regions As Variant
regions = ThisDrawing.ModelSpace.AddRegion(WheelParts)
' Copy the regions into the region variables for ease of use
Dim WheelOuter As AcadRegion
Dim WheelInner As AcadRegion
If regions(0).Area > regions(1).Area Then
' The first region is the outer edge of the wheel
Set WheelOuter = regions(0)
Set WheelInner = regions(1)
Else
' The first region is the inner edge of the wheel
Set WheelInner = regions(0)
Set WheelOuter = regions(1)
End If
' Subtract the smaller circle from the larger circle
WheelOuter.Boolean acSubtraction, WheelInner
相关概念父主题: |
GMT+8, 2026-10-27 21:33
