创建区域 (.NET)
通过创建对象的实例,然后将其追加到 .在将其添加到对象之前,需要根据形成闭环的对象计算区域。该函数在对象的输入数组形成的每个闭环中创建一个区域。该方法返回并需要一个对象。BlockTableRecordRegionBlockTableRecordBlockTableRecordCreateFromCurvesCreateFromCurvesDBObjectCollection AutoCAD 将闭合的 2D 和平面 3D 多段线转换为单独的区域,然后转换形成闭合平面环的多段线、直线和曲线。如果两条以上的曲线共享一个端点,则生成的区域可能是任意的。因此,实际上可以使用该方法创建多个区域。您需要将创建的每个区域附加到对象中。CreateFromCurvesBlockTableRecord 创建简单区域以下示例从单个圆圈创建区域。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("AddRegion")> _
Public Sub AddRegion()
'' Start a transaction
Dim acBlkTbl As BlockTable
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
OpenMode.ForWrite)
'' Create an in memory circle
Using acCirc As Circle = New Circle()
acCirc.Center = New Point3d(2, 2, 0)
acCirc.Radius = 5
'' Adds the circle to an object array
Dim acDBObjColl As DBObjectCollection = New DBObjectCollection()
acDBObjColl.Add(acCirc)
'' Calculate the regions based on each closed loop
Dim myRegionColl As DBObjectCollection = New DBObjectCollection()
myRegionColl = Region.CreateFromCurves(acDBObjColl)
Dim acRegion As Region = myRegionColl(0)
acBlkTblRec.AppendEntity(acRegion)
acTrans.AddNewlyCreatedDBObject(acRegion, True)
'' Dispose of the in memory object not appended to the database
End Using
'' Save the new object to the database
acTrans.Commit()
End Using
[CommandMethod("AddRegion")]
public static void AddRegion()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Create an in memory circle
using (Circle acCirc = new Circle())
acCirc.Center = new Point3d(2, 2, 0);
acCirc.Radius = 5;
// Adds the circle to an object array
DBObjectCollection acDBObjColl = new DBObjectCollection();
acDBObjColl.Add(acCirc);
// Calculate the regions based on each closed loop
DBObjectCollection myRegionColl = new DBObjectCollection();
myRegionColl = Region.CreateFromCurves(acDBObjColl);
Region acRegion = myRegionColl[0] as Region;
acBlkTblRec.AppendEntity(acRegion);
acTrans.AddNewlyCreatedDBObject(acRegion, true);
// Dispose of the in memory circle not appended to the database
// Save the new object to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub AddRegion()
' Define an array to hold the
' boundaries of the region.
Dim curves(0 To 0) As AcadCircle
' Create a circle to become a
' boundary for the region.
Dim center(0 To 2) As Double
Dim radius As Double
center(0) = 2
center(1) = 2
center(2) = 0
radius = 5#
Set curves(0) = ThisDrawing.ModelSpace.AddCircle _
(center, radius)
' Create the region
Dim regionObj As Variant
regionObj = ThisDrawing.ModelSpace.AddRegion(curves)
ZoomAll
相关概念父主题: |
GMT+8, 2026-10-27 13:26
