创建样条对象 (.NET)
此示例使用三个点 (0, 0, 0)、(5, 5, 0) 和 (10, 0, 0) 在模型空间中创建一个圆。样条的起点和终点切线为 (0.5, 0.5, 0.0)。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("AddSpline")> _
Public Sub AddSpline()
'' Start a transaction
Dim acBlkTbl As BlockTable
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
OpenMode.ForWrite)
'' Define the fit points for the spline
Dim ptColl As Point3dCollection = New Point3dCollection()
ptColl.Add(New Point3d(0, 0, 0))
ptColl.Add(New Point3d(5, 5, 0))
ptColl.Add(New Point3d(10, 0, 0))
'' Get a 3D vector from the point (0.5,0.5,0)
Dim vecTan As Vector3d = New Point3d(0.5, 0.5, 0).GetAsVector
'' Create a spline through (0, 0, 0), (5, 5, 0), and (10, 0, 0) with a
'' start and end tangency of (0.5, 0.5, 0.0)
Using acSpline As Spline = New Spline(ptColl, vecTan, vecTan, 4, 0.0)
acBlkTblRec.AppendEntity(acSpline)
acTrans.AddNewlyCreatedDBObject(acSpline, True)
End Using
'' Save the new object to the database
acTrans.Commit()
End Using
[CommandMethod("AddSpline")]
public static void AddSpline()
// Start a transaction
BlockTable acBlkTbl;
BlockTableRecord acBlkTblRec;
// Define the fit points for the spline
Point3dCollection ptColl = new Point3dCollection();
ptColl.Add(new Point3d(0, 0, 0));
ptColl.Add(new Point3d(5, 5, 0));
ptColl.Add(new Point3d(10, 0, 0));
// Get a 3D vector from the point (0.5,0.5,0)
Vector3d vecTan = new Point3d(0.5, 0.5, 0).GetAsVector();
// Create a spline through (0, 0, 0), (5, 5, 0), and (10, 0, 0) with a
// start and end tangency of (0.5, 0.5, 0.0)
using (Spline acSpline = new Spline(ptColl, vecTan, vecTan, 4, 0.0))
acBlkTblRec.AppendEntity(acSpline);
acTrans.AddNewlyCreatedDBObject(acSpline, true);
// Save the new line to the database
acTrans.Commit();
VBA/ActiveX 代码参考Sub AddSpline()
' This example creates a spline object in model space.
' Declare the variables needed
Dim splineObj As AcadSpline
Dim startTan(0 To 2) As Double
Dim endTan(0 To 2) As Double
Dim fitPoints(0 To 8) As Double
' Define the variables
startTan(0) = 0.5: startTan(1) = 0.5: startTan(2) = 0
endTan(0) = 0.5: endTan(1) = 0.5: endTan(2) = 0
fitPoints(0) = 1: fitPoints(1) = 1: fitPoints(2) = 0
fitPoints(3) = 5: fitPoints(4) = 5: fitPoints(5) = 0
fitPoints(6) = 10: fitPoints(7) = 0: fitPoints(8) = 0
' Create the spline
Set splineObj = ThisDrawing.ModelSpace.AddSpline _
(fitPoints, startTan, endTan)
ZoomAll
相关概念父主题: |
GMT+8, 2026-10-28 17:36
