创建折线对象 (.NET)
2024-5-18 17:56| 发布者: admin| 查看: 671| 评论: 0|原作者: admin|来自: AutoCAD
创建折线对象 (.NET)
本示例使用 2D 坐标 (2,4)、(4,2) 和 (6,4) 将一条具有两条直线段的轻量级折线添加到模型空间。
VB.NET
<CommandMethod("AddLightweightPolyline")> _
Public Sub AddLightweightPolyline()
    '' Start a transaction
        Dim acBlkTbl As BlockTable
        acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
                                        OpenMode.ForWrite)
        '' Create a polyline with two segments (3 points)
        Using acPoly As Polyline = New Polyline()
            acPoly.AddVertexAt(0, New Point2d(2, 4), 0, 0, 0)
            acPoly.AddVertexAt(1, New Point2d(4, 2), 0, 0, 0)
            acPoly.AddVertexAt(2, New Point2d(6, 4), 0, 0, 0)
            acBlkTblRec.AppendEntity(acPoly)
            acTrans.AddNewlyCreatedDBObject(acPoly, True)
        End Using
        '' Save the new object to the database
        acTrans.Commit()
    End Using
C#
[CommandMethod("AddLightweightPolyline")]
public static void AddLightweightPolyline()
    // Start a transaction
        BlockTable acBlkTbl;
        BlockTableRecord acBlkTblRec;
        // Create a polyline with two segments (3 points)
        using (Polyline acPoly = new Polyline())
            acPoly.AddVertexAt(0, new Point2d(2, 4), 0, 0, 0);
            acPoly.AddVertexAt(1, new Point2d(4, 2), 0, 0, 0);
            acPoly.AddVertexAt(2, new Point2d(6, 4), 0, 0, 0);
            acBlkTblRec.AppendEntity(acPoly);
            acTrans.AddNewlyCreatedDBObject(acPoly, true);
        // Save the new object to the database
        acTrans.Commit();
VBA/ActiveX 代码参考
Sub AddLightWeightPolyline()
    Dim points(0 To 5) As Double
    ' Define the 2D polyline points
    points(0) = 2: points(1) = 4
    points(2) = 4: points(3) = 2
    points(4) = 6: points(5) = 4
    ' Create a light weight Polyline object in model space
    Set plineObj = ThisDrawing.ModelSpace. _
                   AddLightWeightPolyline(points)
相关概念
  1. 创建行 (.NET)
  1. 创建行 (.NET)
GMT+8, 2026-10-28 01:28
