升级和降级打开的对象 (.NET)
通过升级或降级对象,可以将对象的当前打开模式从读取更改为写入或写入为读取。 这些方法可用于升级或降级以前打开的对象:
建议使用与对象使用方式最匹配的模式打开对象,因为打开对象进行读取和查询对象属性比打开对象进行写入和查询对象属性更有效。如果不确定是否需要修改对象,最好打开对象进行读取,然后升级它进行写入,因为这有助于减少程序的开销。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("FreezeDoorLayer")> _
Public Sub FreezeDoorLayer()
'' Start a transaction
'' Open the Layer table for read
Dim acLyrTbl As LayerTable
acLyrTbl = acTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForRead)
'' Step through each layer and update those that start with 'Door'
For Each acObjId As ObjectId In acLyrTbl
'' Open the Layer table record for read
Dim acLyrTblRec As LayerTableRecord
acLyrTblRec = acTrans.GetObject(acObjId, OpenMode.ForRead)
'' Check to see if the layer's name starts with 'Door'
If (acLyrTblRec.Name.StartsWith("Door", _
StringComparison.OrdinalIgnoreCase) = True) Then
'' Check to see if the layer is current, if so then do not freeze it
If acLyrTblRec.ObjectId <> acCurDb.Clayer Then
'' Change from read to write mode
acTrans.GetObject(acObjId, OpenMode.ForWrite)
'' Freeze the layer
acLyrTblRec.IsFrozen = True
End If
End If
Next
'' Commit the changes and dispose of the transaction
acTrans.Commit()
End Using
[CommandMethod("FreezeDoorLayer")]
public static void FreezeDoorLayer()
// Start a transaction
// Open the Layer table for read
LayerTable acLyrTbl;
OpenMode.ForRead) as LayerTable;
// Step through each layer and update those that start with 'Door'
foreach (ObjectId acObjId in acLyrTbl)
// Open the Layer table record for read
LayerTableRecord acLyrTblRec;
OpenMode.ForRead) as LayerTableRecord;
// Check to see if the layer's name starts with 'Door'
if (acLyrTblRec.Name.StartsWith("Door",
StringComparison.OrdinalIgnoreCase) == true)
// Check to see if the layer is current, if so then do not freeze it
if (acLyrTblRec.ObjectId != acCurDb.Clayer)
// Change from read to write mode
acTrans.GetObject(acObjId, OpenMode.ForWrite);
// Freeze the layer
acLyrTblRec.IsFrozen = true;
// Commit the changes and dispose of the transaction
acTrans.Commit();
父主题: |
GMT+8, 2026-10-27 14:27
