设置和返回系统变量 (.NET)
Application 对象提供了用于设置和检索 AutoCAD 系统变量的 and 方法。例如,若要将整数分配给 MAXSORT 系统变量,请使用以下代码:SetSystemVariableGetSystemVariable VB.NET'' Get the current value from a system variable
Dim nMaxSort as Integer = Application.GetSystemVariable("MAXSORT")
'' Set system variable to new value
Application.SetSystemVariable("MAXSORT", 100)
C#// Get the current value from a system variable
int nMaxSort = System.Convert.ToInt32(Application.GetSystemVariable("MAXSORT"));
// Set system variable to new value
Application.SetSystemVariable("MAXSORT", 100);
VBA/ActiveX 代码参考'' Get the current value from a system variable
nMaxSort = ThisDrawing.GetVariable("MAXSORT")
ThisDrawing.SetVariable "MAXSORT", 100
相关概念父主题: |
GMT+8, 2026-11-11 04:56
