使用命名视图 (.NET)
您可以命名和保存要重用的视图。当您不再需要该视图时,可以将其删除。 命名视图存储在视图表中,该表是工程图数据库中的命名符号表之一。使用向 View 表添加新视图的方法创建命名视图。将新的命名视图添加到“视图”(View) 表时,将创建缺省模型空间视图。Add 您可以在创建视图时为其命名。视图的名称长度最多为 255 个字符,包含字母、数字和特殊字符美元符号 ($)、连字符 (-) 和下划线 (_)。 只需使用要删除的对象的方法,即可从 View 表中删除命名视图。EraseViewTableRecord 添加命名视图并将其设置为当前视图以下示例将命名视图添加到图形中,并将其设置为当前视图。 VB.NETImports Autodesk.AutoCAD.ApplicationServices
<CommandMethod("CreateNamedView")> _
Public Sub CreateNamedView()
'' Get the current database
'' Start a transaction
'' Open the View table for read
Dim acViewTbl As ViewTable
acViewTbl = acTrans.GetObject(acCurDb.ViewTableId, OpenMode.ForRead)
'' Check to see if the named view 'View1' exists
If (acViewTbl.Has("View1") = False) Then
'' Open the View Table for write
acTrans.GetObject(acCurDb.ViewTableId, OpenMode.ForWrite)
'' Create a new View table record and name the view "View1"
Using acViewTblRec As ViewTableRecord = New ViewTableRecord()
acViewTblRec.Name = "View1"
'' Add the new View table record to the View table and the transaction
acViewTbl.Add(acViewTblRec)
acTrans.AddNewlyCreatedDBObject(acViewTblRec, True)
'' Set 'View1' current
acDoc.Editor.SetCurrentView(acViewTblRec)
End Using
'' Commit the changes
acTrans.Commit()
End If
'' Dispose of the transaction
End Using
C#using Autodesk.AutoCAD.ApplicationServices;
[CommandMethod("CreateNamedView")]
public static void CreateNamedView()
// Get the current database
// Start a transaction
// Open the View table for read
ViewTable acViewTbl;
OpenMode.ForRead) as ViewTable;
// Check to see if the named view 'View1' exists
if (acViewTbl.Has("View1") == false)
// Open the View table for write
acTrans.GetObject(acCurDb.ViewTableId, OpenMode.ForWrite);
// Create a new View table record and name the view 'View1'
using (ViewTableRecord acViewTblRec = new ViewTableRecord())
acViewTblRec.Name = "View1";
// Add the new View table record to the View table and the transaction
acViewTbl.Add(acViewTblRec);
acTrans.AddNewlyCreatedDBObject(acViewTblRec, true);
// Set 'View1' current
acDoc.Editor.SetCurrentView(acViewTblRec);
// Commit the changes
acTrans.Commit();
// Dispose of the transaction
VBA/ActiveX 代码参考Sub CreateNamedView()
' Add a named view to the views collection
Dim viewObj As AcadView
Set viewObj = ThisDrawing.Views.Add("View1")
ThisDrawing.ActiveViewport.SetView viewObj
擦除命名视图以下示例从图形中删除命名视图。 VB.NETImports Autodesk.AutoCAD.ApplicationServices
<CommandMethod("EraseNamedView")> _
Public Sub EraseNamedView()
If (acViewTbl.Has("View1") = True) Then
'' Open the View table for write
'' Get the named view
Dim acViewTblRec As ViewTableRecord
acViewTblRec = acTrans.GetObject(acViewTbl("View1"), OpenMode.ForWrite)
'' Remove the named view from the View table
acViewTblRec.Erase()
acTrans.Commit()
End If
End Using
[CommandMethod("EraseNamedView")]
public static void EraseNamedView()
if (acViewTbl.Has("View1") == true)
// Get the named view
ViewTableRecord acViewTblRec;
acViewTblRec = acTrans.GetObject(acViewTbl["View1"],
OpenMode.ForWrite) as ViewTableRecord;
// Remove the named view from the View table
acViewTblRec.Erase();
acTrans.Commit();
VBA/ActiveX 代码参考Sub EraseNamedView()
On Error Resume Next
Set viewObj = ThisDrawing.Views("View1")
If Err = 0 Then
' Delete the view
viewObj.Delete
End If
相关概念父主题: |
GMT+8, 2026-10-26 12:21
