IncludeMaterialTextureFile 属性 (ActiveX/ATO)
指定用于材质纹理的图像文件是否包含在传递包中。 支持的平台:仅限 Windows 命名空间:传输塔利布 集会:AcETransmit19.tlb 属性值只读:不 类型:长
言论没有其他评论。 发行信息释放:AutoCAD 2007 及更高版本
例子VB.NET: ' Custom function used to setup a TransmittalInfo object
Private Shared Function TransInfo(ti As TransmittalInfo, destination As String) _
As TransmittalInfo
' Specify the folder that the files should be copied to
If System.IO.Directory.Exists(destination) = False Then
System.IO.Directory.CreateDirectory(destination)
End If
' Assign the location which the transmittal package should be stored
ti.destinationRoot = destination
' Maintain sub directories (0 - False, 1 - True)
ti.preserveSubdirs = vbTrue
' Maintain folder paths
' ti.organizedFolder = 0 and ti.preserveSubdirs = 0 -
' All files are placed in a single folder which is specified
' by the destinationRoot property
' ti.organizedFolder = 1 and ti.preserveSubdirs = 0 -
' Files are placed in a single folder, but maintain one level
' of subdirectory strcuture
' ti.organizedFolder = 0 and ti.preserveSubdirs = 1 -
' Folder structure is maintained, but the paths for
' reference files are not
' ti.organizedFolder = 1 and ti.preserveSubdirs = 1 -
' Folder structure and reference paths are maintained
ti.organizedFolder = vbTrue
' Change referenced files to use relative paths (0 - False, 1 - True)
ti.dataLinkRelativePath = vbTrue
ti.DGNUnderlayRelativePath = vbTrue
ti.DWFUnderlayRelativePath = vbTrue
ti.imageRelativePath = vbTrue
ti.PDFUnderlayRelativePath = vbTrue
ti.xrefRelativePath = vbTrue
' Set the default drawing file format for all DWG, DWT, and DWS files
' SaveDwgFormat.eAutoCAD14 - AutoCAD R14
' SaveDwgFormat.eAutoCAD2000 - AutoCAD 2000
' SaveDwgFormat.eAutoCADR18 - AutoCAD 2004
' SaveDwgFormat.eAutoCADR21 - AutoCAD 2007
' SaveDwgFormat.eAutoCADR24 - AutoCAD 2010
' SaveDwgFormat.eAutoCADR27 - AutoCAD 2013
' SaveDwgFormat.eAutoCADR32 - AutoCAD 2018
' SaveDwgFormat.eNoConversion - Keep current format
ti.saveVersion = SaveDwgFormat.eNoConversion
' Maintain visual fidelity (SAVEFIDELITY system variable)
' 0 - Saved without visual fidelity
' 1 - Annotation objects assigned annotative scales are saved to
' separate layers for each scale used.
' Only affects drawings when saving to AutoCAD 2007 or earlier file formats.
ti.visualFidelity = vbTrue
' Include DWG Xrefs (Unloaded and Unreferenced: 0 - False, 1 - True)
ti.includeXrefDwg = vbTrue
ti.includeUnloadedReferences = vbTrue
ti.includeUnloadedXrefDwg = vbTrue
ti.includeNestedOverlayXrefDwg = vbTrue
' Bind xrefs attached to a drawing (0 - False, 1 - True)
' BindType.eBind - Use the Bind type to bind the xrefs
' BindType.eInsert - Use the Insert type to bind the xrefs
ti.BindType = BindType.eInsert
' Remove paths from xrefs (0 - False, 1 - True)
ti.depathXrefs = vbTrue
' Include images, underlays, and datalink file (0 - False, 1 - True)
ti.includeImageFile = vbTrue
ti.includeDGNUnderlay = vbTrue
ti.includeDWFUnderlay = vbTrue
ti.includePDFUnderlay = vbTrue
ti.includeDataLinkFile = vbTrue
' Include font (SHX/TTF) and font map (FMP) files (0 - False, 1 - True)
ti.includeFontFile = vbTrue
' Reset plotters for layouts in the drawings to None,
' and include plot style (CTB/STB) files (0 - False, 1 - True)
ti.resetPlotter = vbFalse
ti.includePlotFile = vbTrue
' Specify where the plot files are located so the API can resolve the file
' paths (used when includePlotFile = vbTrue or 1)
ti.plotConfigFilePath = Environment.GetEnvironmentVariable("UserProfile") + _
"\AppData\Roaming\Autodesk\AutoCAD <release>\<version>\enu\Plotters"
ti.plotStyleTablePath = Environment.GetEnvironmentVariable("UserProfile") + _
"\AppData\Roaming\Autodesk\AutoCAD <release>\<version>\enu\Plotters\Plot Styles"
' Get the photometric Web and material files used by lights
' and 3D objects for rendering (0 - False, 1 - True)
ti.includePhotometricWebFile = vbTrue
ti.includeMaterialTextureFile = vbTrue
' Purge unused named objects for all drawing files in the
' Transmittal(Package(0 - False, 1 - True))
ti.purgeDatabase = vbFalse
Return ti
End Function
C#: // Custom function used to setup a TransmittalInfo object
private static TransmittalInfo TransInfo(TransmittalInfo ti, string destination)
// Specify the folder that the files should be copied to
if (System.IO.Directory.Exists(destination) == false)
System.IO.Directory.CreateDirectory(destination);
// Assign the location which the transmittal package should be stored
ti.destinationRoot = destination;
// Maintain sub directories (0 - False, 1 - True)
ti.preserveSubdirs = 1;
ti.organizedFolder = 1;
// Change referenced files to use relative paths (0 - False, 1 - True)
ti.dataLinkRelativePath = 1;
ti.DGNUnderlayRelativePath = 1;
ti.DWFUnderlayRelativePath = 1;
ti.imageRelativePath = 1;
ti.PDFUnderlayRelativePath = 1;
ti.xrefRelativePath = 1;
/* Set the default drawing file format for all DWG, DWT, and DWS files
ti.saveVersion = SaveDwgFormat.eNoConversion;
ti.visualFidelity = 1;
// Include DWG Xrefs (Unloaded and Unreferenced: 0 - False, 1 - True)
ti.includeXrefDwg = 1;
ti.includeUnloadedReferences = 1;
ti.includeUnloadedXrefDwg = 1;
ti.includeNestedOverlayXrefDwg = 1;
ti.BindType = BindType.eInsert;
// Remove paths from xrefs (0 - False, 1 - True)
ti.depathXrefs = 1;
// Include images, underlays, and datalink file (0 - False, 1 - True)
ti.includeImageFile = 1;
ti.includeDGNUnderlay = 1;
ti.includeDWFUnderlay = 1;
ti.includePDFUnderlay = 1;
ti.includeDataLinkFile = 1;
// Include font (SHX/TTF) and font map (FMP) files (0 - False, 1 - True)
ti.includeFontFile = 1;
// Reset plotters for layouts in the drawings to None,
// and include plot style (CTB/STB) files (0 - False, 1 - True)
ti.resetPlotter = 0;
ti.includePlotFile = 1;
// Specify where the plot files are located so the API can resolve the file
// paths (used when includePlotFile = True or 1)
"\\AppData\\Roaming\\Autodesk\\AutoCAD <release>\\<version>\\enu\\Plotters";
"\\AppData\\Roaming\\Autodesk\\AutoCAD <release>\\<version>\\enu\\Plotters\\Plot Styles";
// Get the photometric Web and material files used by lights
// and 3D objects for rendering (0 - False, 1 - True)
ti.includePhotometricWebFile = 1;
ti.includeMaterialTextureFile = 1;
// Purge unused named objects for all drawing files in the
// Transmittal(Package(0 - False, 1 - True))
ti.purgeDatabase = 0;
return ti;
相关参考 |
GMT+8, 2026-10-28 01:29
