IncludeInTransmittal 属性 (ActiveX/ATO)
2024-5-18 17:55| 发布者: admin| 查看: 736| 评论: 0|原作者: admin|来自: AutoCAD
指示是否应将文件包含在传递包中。
命名空间:传输塔利布
集会:AcETransmit19.tlb
VBA/VB.NET/C#:
object.includeInTransmittal
类型:TransmittalFile
此属性应用于的对象。
只读:不
类型:长
  • 0 (False) - 文件将从传递包中排除
  • 1 (True) - 文件将包含在传输包中
发行信息
释放:AutoCAD 2004 及更高版本
  • AcETransmit19.tlb - AutoCAD 2015 及更高版本
  • AcETransmit18.tlb - AutoCAD 2010 到 AutoCAD 2014
    • 该接口已与该接口合并,并且该特性不再仅在 AutoCAD 2010 版本的库中标记为供 Autodesk 内部使用。ITransmittalFile2ITransmittalFileincludeInTransmittal
  • AcETransmit16.tlb - AutoCAD 2004 到 AutoCAD 2009
    • 该方法最初是在 AutoCAD 2004 版库中的界面中引入的,但标记为仅供 Autodesk 内部使用。includeInTransmittalITransmittalFile
VB.NET:
' Custom command that information about a file
<CommandMethod("FileInfo")> _
Public Shared Sub FileInfo()
    ' Define file to add to the transmittal
    Dim tf As TransmittalFile = Nothing
    Dim dwgFile As String = "C:\AutoCAD\Sample\Sheet Sets\Architectural\A-01.dwg"
    ' Add file to transmittal and parse its information
    If tro.addDrawingFile(dwgFile, tf) = AddFileReturnVal.eFileAdded Then
        ' Get the current editor
        Dim acEditor As Editor = Application.DocumentManager.MdiActiveDocument.Editor
        ' Output information about the root file of the transmittal set
        ' Source and full target path to the file
        acEditor.WriteMessage(Environment.NewLine & "Source Path: " & tf.sourcePath)
        acEditor.WriteMessage(Environment.NewLine & "Full Path: " & tf.fullPathForTarget)
        acEditor.WriteMessage(Environment.NewLine & "Target SubPath: " & tf.targetSubPath)
        ' See if the root file is a drawing
        If System.IO.Path.GetExtension(tf.sourcePath).ToUpper() = ".DWG" Then
            ' Number of dependents and dependees
            acEditor.WriteMessage(Environment.NewLine & "# of Dependents: " & tf.numberOfDependents.ToString())
            acEditor.WriteMessage(Environment.NewLine & "# of Dependees: " & tf.numberOfDependees.ToString())
        End If
        ' Output file system information about the root file
        acEditor.WriteMessage(Environment.NewLine & "File Exists: " & tf.fileExists.ToString())
        acEditor.WriteMessage(Environment.NewLine & "File Size: " & tf.fileSize.ToString())
        acEditor.WriteMessage(Environment.NewLine & "File Type: " & tf.FileType.ToString())
        acEditor.WriteMessage(Environment.NewLine & "Include in transmittal: " & tf.includeInTransmittal.ToString())
        acEditor.WriteMessage(Environment.NewLine & "Date/Time: " & tf.lastModifiedTime.ToLongDateString() & "  " &
        tf.lastModifiedTime.ToLongTimeString())
        acEditor.WriteMessage(Environment.NewLine & "Type: " & tf.type.ToString())
        acEditor.WriteMessage(Environment.NewLine & "Version: " & tf.version.ToString())
    End If
C#:
// Custom command that information about a file
[CommandMethod("FileInfo")]
public static void FileInfo()
    TransmittalInfo ti = TransInfo(tro.getTransmittalInfoInterface(), @"C:\Users\Public\TransmittalAPITest\");
    // Define file to add to the transmittal
    TransmittalFile tf = null;
    string dwgFile = @"C:\AutoCAD\Sample\Sheet Sets\Architectural\A-01.dwg";
    // Add file to transmittal and parse its information
    if (tro.addDrawingFile(dwgFile, out tf) == AddFileReturnVal.eFileAdded)
        // Get the current editor
        Editor acEditor = Application.DocumentManager.MdiActiveDocument.Editor;
        // Output information about the root file of the transmittal set
        // Source and full target path to the file
        acEditor.WriteMessage(Environment.NewLine + "Source Path: " + tf.sourcePath);
        acEditor.WriteMessage(Environment.NewLine + "Full Path: " + tf.fullPathForTarget);
        acEditor.WriteMessage(Environment.NewLine + "Target SubPath: " + tf.targetSubPath);
        // See if the root file is a drawing
        if (Path.GetExtension(tf.sourcePath).ToUpper() == ".DWG")
            // Number of dependents and dependees
            acEditor.WriteMessage(Environment.NewLine + "# of Dependents: " + tf.numberOfDependents.ToString());
            acEditor.WriteMessage(Environment.NewLine + "# of Dependees: " + tf.numberOfDependees.ToString());
        // Output file system information about the root file
        acEditor.WriteMessage(Environment.NewLine + "File Exists: " + tf.fileExists.ToString());
        acEditor.WriteMessage(Environment.NewLine + "File Size: " + tf.fileSize.ToString());
        acEditor.WriteMessage(Environment.NewLine + "File Type: " + tf.FileType.ToString());
        acEditor.WriteMessage(Environment.NewLine + "Include in transmittal: " + tf.includeInTransmittal.ToString());
        acEditor.WriteMessage(Environment.NewLine + "Date/Time: " + tf.lastModifiedTime.ToLongDateString() + "  " +
        tf.lastModifiedTime.ToLongTimeString());
        acEditor.WriteMessage(Environment.NewLine + "Type: " + tf.type.ToString());
        acEditor.WriteMessage(Environment.NewLine + "Version: " + tf.version.ToString());
GMT+8, 2026-10-26 12:22
