Count 属性 (ActiveX/CSP)
2024-5-18 17:54| 发布者: admin| 查看: 688| 评论: 0|原作者: admin|来自: AutoCAD
获取对象中的项数。
命名空间:AcStMgr (英语)
集会:AcStMgr.tlb
VB.NET:
object.Count
C#:
object.Count;
类型:AcStModelSpaceProxy、AcStPaperSpaceProxy 对象
此属性应用于的对象。
只读:是的
类型:长
对象中的项数。
发行信息
释放:AutoCAD 2004 及更高版本
VB.NET:
Public Sub SetupForAudit(ByVal pDb As AcadDatabase, _
                         ByVal szPathName As String, _
                         ByVal stdNameArray As Object, _
                         ByVal stdPathArray As Object, _
                         ByVal stdDbArray As Object) _
                               Implements IAcStPlugin2.SetupForAudit
    ' Number of graphical objects contained in model space and paper space of
    ' the database being checked
    If Not IsNothing(pDb) Then
        Dim msProxy As IAcStBlockProxy = m_pManager.ModelSpaceProxy(pDb)
        Dim psProxy As IAcStBlockProxy = m_pManager.PaperSpaceProxy(pDb)
        Debug.Print("Object counts " & vbLf & "Model: " & msProxy.Count.ToString() &
                    vbLf & "Paper: " & psProxy.Count.ToString())
    End If
C#:
public void SetupForAudit(AcadDatabase pDb, string szPathName, object stdNameArray,
                          object stdPathArray, object stdDbArray)
    // Number of graphical objects contained in model space and paper space of
    // the database being checked
    if (pDb != null)
        IAcStBlockProxy msProxy = m_pManager.get_ModelSpaceProxy(pDb);
        IAcStBlockProxy psProxy = m_pManager.get_PaperSpaceProxy(pDb);
        Debug.Print("Object counts \nModel: " + msProxy.Count.ToString() +
                    "\nPaper: " + psProxy.Count.ToString());
GMT+8, 2026-10-28 09:54
