Clear 方法 (ActiveX/CSP)
2024-5-18 17:54| 发布者: admin| 查看: 867| 评论: 0|原作者: admin|来自: AutoCAD
在从内存中释放插件或用于清除任何缓存的错误之前触发。
命名空间:AcStMgr (英语)
集会:AcStMgr.tlb
签名 - AcStErrorIterator 对象
仅供内部使用。
VB.NET:
object.Clear()
C#:
object.Clear();
类型:AcStErrorIterator 对象
此方法应用到的对象。
签名 - IAcStPlugin2 接口
VB.NET:
Public Sub Clear() _
                Implements AcStMgr.IAcStPlugin2.Clear
C#:
public void Clear()
类型:IAcStPlugin2 接口
此方法适用的接口。
返回值 (RetVal)
无返回值。
发行信息
释放:AutoCAD 2004 及更高版本
示例 - AcStErrorIterator 对象
VB.NET:
Not available
C#:
Not available
示例 - IAcStPlugin2 接口
VB.NET:
Public Sub PlugIn_Clear() Implements IAcStPlugin2.Clear
    ' If the XML Document object exist, the plug-in is being used by the Batch Standards Checker.
    ' Output the standards items that were used for comparison to the Standards Items section.
    If IsNothing(m_xmlDoc) = False Then
        WriteStandardsItemsInfo()
    End If
    ' Clean up the global variables
    m_xmlDoc = Nothing
    m_pPlugin = Nothing
    m_curIndex = -1
    m_RecommendedFixIndex = -1
    m_FixCnt = 0
    m_pManager = Nothing
    m_pDWSDatabase = Nothing
    m_pCheckDatabase = Nothing
    If IsNothing(m_pError) = False Then
        m_pError.Reset()
        m_pError = Nothing
    End If
    ' << Change based on standards implementation >>
    If IsNothing(m_LayerCacheArray) = False Then
        Dim i As Integer
        For i = 0 To UBound(m_LayerCacheArray)
            If IsDBNull(m_LayerCacheArray(i).StandardsFix) = False Then
                m_LayerCacheArray(i).StandardsFix.Reset()
                m_LayerCacheArray(i).StandardsFix = Nothing
            End If
        Next
        Erase m_LayerCacheArray
    End If
    If IsNothing(m_FixArray) = False Then
        Erase m_FixArray
    End If
    m_ContextList.Clear()
C#:
public void PlugIn_Clear()
    // If the XML Document object exist, the plug-in is being used by the Batch Standards Checker.
    // Output the standards items that were used for comparison to the Standards Items section.
    if ((m_xmlDoc == null) == false)
        WriteStandardsItemsInfo();
    // Clean up the global variables
    m_xmlDoc = null;
    m_pPlugin = null;
    m_curIndex = -1;
    m_RecommendedFixIndex = -1;
    m_FixCnt = 0;
    m_pManager = null;
    m_pDWSDatabase = null;
    m_pCheckDatabase = null;
    if ((m_pError == null) == false)
        m_pError.Reset();
        m_pError = null;
    // << Change based on standards implementation >>
    if ((m_LayerCacheArray == null) == false)
        int i = 0;
        int nLBound = m_LayerCacheArray.GetLowerBound(0);
        int nUBound = m_LayerCacheArray.GetUpperBound(0);
        for (i = 0; i <= nUBound; i++)
            if (m_LayerCacheArray[i].StandardsFix != null)
                m_LayerCacheArray[i].StandardsFix.Reset();
                m_LayerCacheArray[i].StandardsFix = null;
        m_LayerCacheArray = null;
    if ((m_FixArray == null) == false)
        m_FixArray = null;
    m_ContextList.Clear();
void IAcStPlugin2.Clear()
    PlugIn_Clear();
GMT+8, 2026-11-15 12:36
