VersionGUID 属性 (ActiveX)
指定文件依赖项列表中条目的版本 GUID 的名称。(已过时) 支持的平台:仅限 Windows 属性值只读:是的 类型:字符串 条目的 GUID 版本。 言论没有其他评论。 例子VBA: Sub Example_VersionGUID()
' This example reads information from a File Dependency List
' Open a drawing from the sample Sheet Sets that contains xrefs, such as
' \Sample\Sheet Sets\Architectural\A-01.dwg
Dim objFDLCol As AutoCAD.AcadFileDependencies
Dim objFDL As AutoCAD.AcadFileDependency
Set objFDLCol = ThisDrawing.FileDependencies
MsgBox ("The number of entries in the File Dependency List is " & objFDLCol.count & ".")
Dim strTemp As String
For Each objFDL In objFDLCol
strTemp = "Affects graphics?: " & vbTab & objFDL.AffectsGraphics
strTemp = strTemp & vbCrLf & "Feature: " & vbTab & objFDL.Feature
strTemp = strTemp & vbCrLf & "FileName: " & vbTab & objFDL.FileName
strTemp = strTemp & vbCrLf & "FileSize: " & vbTab & objFDL.FileSize
strTemp = strTemp & vbCrLf & "Fingerprint GUID: " & vbTab & objFDL.FingerprintGuid
strTemp = strTemp & vbCrLf & "FoundPath: " & vbTab & objFDL.FoundPath
strTemp = strTemp & vbCrLf & "FullFileName: " & vbTab & objFDL.FullFileName
strTemp = strTemp & vbCrLf & "Index: " & vbTab & objFDL.Index
strTemp = strTemp & vbCrLf & "Modified?: " & vbTab & objFDL.IsModified
strTemp = strTemp & vbCrLf & "ReferenceCount: " & vbTab & objFDL.ReferenceCount
strTemp = strTemp & vbCrLf & "Timestamp: " & vbTab & objFDL.TimeStamp
strTemp = strTemp & vbCrLf & "Version GUID: " & vbTab & objFDL.VersionGuid
MsgBox strTemp
Next
可视化 LISP: (vl-load-com)
(defun c:Example_VersionGUID()
;; This example reads information from a File Dependency List
;; Open a drawing from the sample Sheet Sets that contains xrefs, such as
;; .\\Sample\\Sheet Sets\\Architectural\\A-01.dwg
(setq objFDLCol (vla-get-FileDependencies doc))
(alert (strcat "The number of entries in the File Dependency List is " (itoa (vla-get-Count objFDLCol)) "."))
(setq strTemp "")
(vlax-for each-objFDL objFDLCol
(setq strTemp (strcat "Affects graphics?: " (if (= (vla-get-AffectsGraphics each-objFDL) :vlax-true) "True" "False")))
(setq strTemp (strcat strTemp
"\nFeature: " (vla-get-Feature each-objFDL)
"\nFileName: " (vla-get-FileName each-objFDL)
"\nFileSize: " (itoa (vla-get-FileSize each-objFDL))
"\nFingerprint GUID: " (vla-get-FingerprintGuid each-objFDL)
"\nFoundPath: " (vla-get-FoundPath each-objFDL)
"\nFullFileName: " (vla-get-FullFileName each-objFDL)
"\nIndex: " (itoa (vla-get-Index each-objFDL))
"\nModified?: " (if (= (vla-get-IsModified each-objFDL) :vlax-true) "True" "False")
"\nReferenceCount: " (itoa (vla-get-ReferenceCount each-objFDL))
"\nTimeStamp: " (itoa (vla-get-TimeStamp each-objFDL))
"\nVersion GUID: " (vla-get-VersionGuid each-objFDL)
(alert strTemp)
GMT+8, 2026-10-27 13:30
