ProviderName 属性 (ActiveX)
2024-5-18 17:54| 发布者: admin| 查看: 647| 评论: 0|原作者: admin|来自: AutoCAD
指定加密提供程序名称。(已过时)
object.ProviderName
类型:SecurityParams
此属性应用于的对象。
只读:不
类型:字符串
加密提供程序名称。有关加密提供程序的详细信息,请访问 MSDN (https://msdn.microsoft.com)。
注意:从基于 AutoCAD-2016 的产品开始,已停止使用密码保护图形文件的功能。
Sub Example_ProviderName()
    ' This example encrypts and saves a file.
    Dim sp As AcadSecurityParams
    Set sp = GetInterfaceObject("AutoCAD.SecurityParams.20")
    sp.Action = AcadSecurityParamsType.ACADSECURITYPARAMS_ENCRYPT_DATA
    sp.Algorithm = AcadSecurityParamsConstants.ACADSECURITYPARAMS_ALGID_RC4
    sp.KeyLength = 40
    sp.Password = UCase("mypassword") 'AutoCAD converts all passwords to uppercase before applying them
    sp.ProviderName = "Microsoft Base Cryptographic Provider v1.0"
    sp.ProviderType = 1
    ThisDrawing.SaveAs "C:\MyDrawing.dwg", , sp
(defun c:Example_ProviderName()
    ;; This example encrypts and saves a drawing file.
    (setq sp (vlax-create-object "AutoCAD.SecurityParams.20"))
    (vla-put-Visible acadObj :vlax-true)
    (vla-put-Action sp ACADSECURITYPARAMS_ENCRYPT_DATA)
    (vla-put-Algorithm sp ACADSECURITYPARAMS_ALGID_RC4)
    (vla-put-KeyLength sp 40)
    (vla-put-Password sp (strcase "mypassword"))
    (vla-put-ProviderName sp "Microsoft Base Cryptographic Provider v1.0")
    (vla-put-ProviderType sp 1)
    (vla-SaveAs doc "C:\\MyDrawing.dwg" acNative sp)
    (vlax-release-object sp)
GMT+8, 2026-10-26 19:49
