SelectionChanged 事件 (ActiveX)
在当前 pickfirst 选择集更改时触发。 支持的平台:仅限 Windows 言论显示模式对话框时不会触发任何事件。 例子VBA: Private Sub AcadDocument_SelectionChanged()
' This example intercepts a drawing SelectionChanged event.
' This event is triggered when the current selection set in a drawing is modified.
' To trigger this example event: Select or deselect objects in any open drawing
MsgBox "The selection set in a drawing was just changed!"
可视化 LISP: Not available |
GMT+8, 2026-10-28 17:18
