ObjectModified 事件 (ActiveX)
在修改图形中的对象时触发。 支持的平台:仅限 Windows 签名VBA: object.ObjectModified(Entity) 言论此事件在修改操作完成后发生。 显示模式对话框时不会触发任何事件。 例子VBA: Private Sub AcadDocument_ObjectModified(ByVal Object As Object)
' This example intercepts a drawing ObjectModified event.
' This event is triggered when an object in a drawing is modified.
' To trigger this example event: Modify an object in any open drawing
' Use the "Object" variable to determine the type of object modified
MsgBox "A " & TypeName(Object) & " was just modified!"
可视化 LISP: Not available |
GMT+8, 2026-10-27 13:30
