ObjectErased 事件 (ActiveX)
当对象从图形中删除时触发。 支持的平台:仅限 Windows 签名VBA: object.ObjectErased(ObjectID)
言论显示模式对话框时不会触发任何事件。 例子VBA: Private Sub AcadDocument_ObjectErased(ByVal ObjectID As Long_PTR)
' This example intercepts a drawing ObjectErased event.
' This event is triggered when an object is removed from a drawing.
' To trigger this example event: Delete (Cut) an existing object from an open drawing
' Use the "Object" variable to determine the type of object removed
MsgBox "The ID of the object deleted is: " & ObjectID
可视化 LISP: Not available |
GMT+8, 2026-10-27 13:29
