LayoutSwitched 事件 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 839| 评论: 0|原作者: admin|来自: AutoCAD
在用户切换到其他布局后触发。
object.LayoutSwitched(LayoutName)
类别: 文档
计算结果为有效容器对象的对象表达式。在这种情况下,唯一有效的容器是文档。
布局名称
类型:字符串;输入到处理程序
用户切换到的布局的名称。
显示模式对话框时不会触发任何事件。
Private Sub AcadDocument_LayoutSwitched(ByVal LayoutName As String)
    ' This example intercepts a drawing LayoutSwitched event.
    ' This event is triggered when the user switches to a different
    ' drawing layout view.
    ' To trigger this example event: Open a drawing and change its layout view
    ' For example: Switch the drawing from Model view to Layout1 view
    ' Use the "LayoutName" variable to determine the which layout view we changed to
    MsgBox "The drawing layout was just changed to: " & LayoutName
Not available
GMT+8, 2026-10-27 22:03
