EndPlot 事件 (ActiveX)
在将文档发送到打印机后触发。 支持的平台:仅限 Windows 签名VBA: object.EndPlot(DrawingName) 言论显示模式对话框时不会触发任何事件。 例子VBA: Private Sub AcadDocument_EndPlot(ByVal DrawingName As String)
' This example intercepts a drawing EndPlot event.
' This event is triggered when a drawing finishes a plot request.
' To trigger this example event: Plot an open drawing and wait for the plot to finish
' Use the "DrawingName" variable to determine which drawing just finished plotting
MsgBox "A drawing has just finished a plot request!"
可视化 LISP: Not available |
GMT+8, 2026-11-15 13:25
