EndLISP 事件 (ActiveX)
在完成计算 AutoLISP 表达式时触发。 支持的平台:仅限 Windows 言论此事件将在 AutoLISP 评估正常终止或取消 AutoLISP 评估后发生。 显示模式对话框时不会触发任何事件。 例子VBA: Private Sub AcadDocument_EndLisp()
' This example intercepts a drawing BeginLisp event.
' This event is triggered when a drawing finishes
' a the evaluation of a LISP expression.
' To trigger this example event: Start the evaluation of a LISP expression and
' wait for it to finish being evaluated
MsgBox "A LISP expression has just finished being evaluated!"
可视化 LISP: Not available |
GMT+8, 2026-10-27 22:02
