停用事件 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 553| 评论: 0|原作者: admin|来自: AutoCAD
停用事件 (ActiveX)
在停用绘图窗口时触发。
object.Deactivate()
类别: 文档
计算结果为有效容器对象的对象表达式。在这种情况下,唯一有效的容器是文档。
显示模式对话框时不会触发任何事件。
Private Sub AcadDocument_Deactivate()
    ' This example intercepts a drawing DeActivate event.
    ' This event is triggered when a drawing window loses focus.
    ' To trigger this example event: Open two drawings and switch from
    ' one drawing window to another
    MsgBox "You have just deactivated a drawing!"
Not available
GMT+8, 2026-10-28 17:41
