BeginSave 事件 (ActiveX)
AutoCAD 收到保存图形的请求后立即触发。 支持的平台:仅限 Windows 签名VBA: object.BeginSave(Filename)
言论一旦AutoCAD收到保存请求以及要保存的文件的名称,就会触发该事件。此请求可以由用户通过界面以交互方式发出,也可以以编程方式发出。BeginSave 该事件之后是 AutoCAD 完成图形保存后的事件。BeginSave EndSave 显示模式对话框时不会触发任何事件。 例子VBA: Private Sub AcadDocument_BeginSave(ByVal FileName As String)
' This example intercepts a drawing BeginSave event.
' This event is triggered when a drawing receives a request to be saved.
' To trigger this example event: Save an open drawing
' Use the "FileName" variable to determine where the drawing file is being saved
MsgBox "A drawing is about to be saved to: " & FileName
可视化 LISP: Not available |
GMT+8, 2026-10-27 13:29
