BeginRightClick 事件 (ActiveX)
在用户右键单击绘图窗口后触发。 支持的平台:仅限 Windows 签名VBA: object.BeginRightClick(PickPoint)
言论显示模式对话框时不会触发任何事件。 例子VBA: Private Sub AcadDocument_BeginRightClick(ByVal PickPoint As Variant)
' This example intercepts a drawing BeginRightClick event.
' This event is triggered when a drawing receives
' a right mouse click in its working area.
' To trigger this example event: Position the cursor over the working area of
' a drawing window and click the right mouse button.
' Use the "PickPoint" variable to determine where on the drawing the user clicked
MsgBox "A drawing has just been right-clicked at:" & vbCrLf & _
PickPoint(0) & vbCrLf & _
PickPoint(1) & vbCrLf & _
PickPoint(2)
可视化 LISP: Not available |
GMT+8, 2026-10-27 20:34
