BeginLISP 事件 (ActiveX)
在 AutoCAD 收到计算 AutoLISP 表达式的请求后立即触发。 支持的平台:仅限 Windows 签名VBA: object.BeginLISP(FirstLine)
言论显示模式对话框时不会触发任何事件。 例子VBA: Private Sub AcadDocument_BeginLisp(ByVal FirstLine As String)
' This example intercepts a drawing BeginLisp event.
' This event is triggered when a drawing receives
' a request to evaluate a LISP expression.
' To trigger this example event: Start the evaluation of a LISP expression
' Use the "FirstLine" variable to help the user determine which LISP expression is running
MsgBox "A LISP expression has just started to be evaluated. The first line of the expression is: " & FirstLine
可视化 LISP: Not available |
GMT+8, 2026-10-26 18:25
