ARXUnloaded 事件 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 938| 评论: 0|原作者: admin|来自: AutoCAD
在卸载 ObjectARX 应用程序时触发。
object.ARXUnloaded(FullPathName)
类型: 应用
计算结果为有效容器对象的对象表达式。在这种情况下,唯一有效的容器是应用程序。
完整路径名称
类型:字符串
已卸载的 ObjectARX 应用程序的完整路径和文件名。
显示模式对话框时不会触发任何事件。
Public WithEvents ACADApp As AcadApplication    ' Use with Application Event Examples
Sub Example_AcadApplication_Events()
    ' This example intializes the public variable (ACADApp) which will be used
    ' to intercept AcadApplication Events
    ' The VBA WithEvents statement makes it possible to intercept an generic object
    ' with the events associated with that object.
    ' Before you will be able to trigger any of the AcadApplication events,
    ' you will first need to run this procedure.
    ' We could get the application from the ThisDocument object, but that would
    ' require having a drawing open, so we grab it from the system.
    Set ACADApp = GetObject(, "AutoCAD.Application.22")
Private Sub ACADApp_ARXUnloaded(ByVal AppName As String)
    ' This example intercepts an Application ARXUnloaded event.
    ' This event is triggered when the AutoCAD unloads an ARX application
    ' To trigger this example event:
    '     1) Make sure to run the example that initializes
    '     the public variable (named ACADApp) linked to this event.
    '     2) Unload an ARX application that is already loaded into AutoCAD
    ' Use the "AppName" variable to notify the user which ARX application was unloaded
      MsgBox "AutoCAD just unloaded the ARX application: " & AppName
Not available
GMT+8, 2026-10-28 07:34
