AppActivate 事件 (ActiveX)
在激活主应用程序窗口之前触发。 支持的平台:仅限 Windows 言论显示模式对话框时不会触发任何事件。 例子VBA: Public WithEvents ACADApp As AcadApplication ' Use with Application Event Examples
Sub Example_AcadApplication_Events()
' This example initializes the public variable (ACADApp), which will be used
' to intercept AcadApplication Events
' The VBA WithEvents statement makes it possible to intercept a generic object
' with the events associated with that object.
' Before you will be able to trigger any of the AcadApplication events,
' you will need to run this procedure.
' We could get the application from the ThisDocument object, but that would
' require having a drawing open, so we get it from the system.
Set ACADApp = GetObject(, "AutoCAD.Application.22")
Private Sub ACADApp_AppActivate()
' This example intercepts an Application AppActivate event.
' This event is triggered when the AutoCAD application receives focus
' To trigger this example event:
' 1) Make sure to run the example that initializes
' the public variable (named ACADApp) linked to this event.
' 2) Switch focus from AutoCAD to another Windows application
' and then back again.
MsgBox "AutoCAD was just activated!"
可视化 LISP: Not available |
GMT+8, 2026-10-28 02:21
