YVector 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 652| 评论: 0|原作者: admin|来自: AutoCAD
指定给定 UCS 的 Y 方向。
object.YVector
类型:UCS
此属性应用于的对象。
只读:
类型:变体(双打的三元素阵列)
指定给定 UCS 的 Y 方向的向量
如果更改活动 UCS 上的 Y 向量值,则必须重置活动 UCS 才能查看更改。若要重置活动 UCS,请使用该属性。ActiveUCS
注意:此属性的值存储在 UCSYDIR 系统变量中。
Sub Example_YVector()
    ' This finds the current setting of YVector for a given UCS.
    ' It then changes the YVector and resets the UCS.
    Dim viewportObj As AcadViewport
    ' Set the viewportObj variable to the active viewport
    Set viewportObj = ThisDrawing.ActiveViewport
    ' Define a new UCS and turn on the UCS icon at the origin.
    Dim ucsObj As AcadUCS
    Dim origin(0 To 2) As Double
    Dim xAxisPoint(0 To 2) As Double
    Dim yAxisPoint(0 To 2) As Double
    origin(0) = 2: origin(1) = 2: origin(2) = 0
    xAxisPoint(0) = 3: xAxisPoint(1) = 2: xAxisPoint(2) = 0
    yAxisPoint(0) = 2: yAxisPoint(1) = 3: yAxisPoint(2) = 0
    Set ucsObj = ThisDrawing.UserCoordinateSystems.Add(origin, xAxisPoint, yAxisPoint, "UCS1")
    ThisDrawing.ActiveUCS = ucsObj
    viewportObj.UCSIconOn = True
    viewportObj.UCSIconAtOrigin = True
    ThisDrawing.ActiveViewport = viewportObj
    ' Display the current setting of the vectors
    MsgBox "The current XVector is: " _
           & ucsObj.XVector(0) & ", " & ucsObj.XVector(1) & ", " & ucsObj.XVector(2) & vbCrLf _
           & "The current YVector is: " _
           & ucsObj.YVector(0) & ", " & ucsObj.YVector(1) & ", " & ucsObj.YVector(2), , "YVector Example"
    ' Change the setting of YVector
    Dim newVector(0 To 2) As Double
    newVector(0) = -1: newVector(1) = -1: newVector(2) = 0
    ucsObj.YVector = newVector
    ' Reset the active UCS to see the change
    MsgBox "The new XVector is: " _
           & "The YVector is: " _
(defun c:Example_YVector()
    ;; This finds the current setting of XVector for a given UCS.
    ;; It then changes the XVector and resets the UCS.
    ;; Set the viewportObj variable to the activeviewport
    (setq viewportObj (vla-get-ActiveViewport doc))
    ;; Define a new UCS and turn on the UCS icon at the origin.
    (setq origin (vlax-3d-point 2 2 0)
          xAxisPoint (vlax-3d-point 3 2 0)
          yAxisPoint (vlax-3d-point 2 3 0))
    (setq ucsObj (vla-Add (vla-get-UserCoordinateSystems doc) origin xAxisPoint yAxisPoint "TEST"))
    (vla-put-ActiveUCS doc ucsObj)
    (vla-put-UCSIconOn viewportObj :vlax-true)
    (vla-put-UCSIconAtOrigin viewportObj :vlax-true)
    (vla-put-ActiveViewport doc viewportObj)
    ;; Display the current setting of the XVector
    (alert (strcat "The current XVector is: "
                   "\n" (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-XVector ucsObj)) 0) 2) ", "
                        (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-XVector ucsObj)) 1) 2) ", "
                        (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-XVector ucsObj)) 2) 2)
                   "\nThe current YVector is: "
                   "\n" (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-YVector ucsObj)) 0) 2) ", "
                        (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-YVector ucsObj)) 1) 2) ", "
                        (rtos (vlax-safearray-get-element (vlax-variant-value (vla-get-YVector ucsObj)) 2) 2)))
    ;; Change the setting of XVector
    (setq newVector (vlax-3d-point 0.7071 0.7071 0))
    (vla-put-XVector ucsObj newVector)
    (setq newVector (vlax-3d-point -0.7071 0.7071 0))
    (vla-put-YVector ucsObj newVector)
    ;; Reset the active UCS to see the change
    (alert (strcat "The new XVector is: "
                   "\nThe new YVector is: "
GMT+8, 2026-9-13 02:42
