XRefFadeIntensity 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 781| 评论: 0|原作者: admin|来自: AutoCAD
控制 XRefs 的调光强度。
object.XRefFadeIntensity
类型:首选项显示
此属性应用于的对象。
只读:不
类型:长
从 1 到 90 的正长整数,表示 XRefs 的衰落百分比。
此属性的初始值为 50。
注意:此属性的值存储在 XFADECTL 系统变量中。
Sub Example_XRefFadeIntensity()
    ' This example reads and modifies the preference value that controls
    ' the dimming intensity for xrefs. When finished, this example resets
    ' the preference value back to its original value.
    ' * Note: Changes can only be observed when in-place editing of an Xref
    ' object is in progress and other entities are visible.
    Dim ACADPref As AcadPreferencesDisplay
    ' Get the display preferences object
    Set ACADPref = ThisDrawing.Application.preferences.DISPLAY
    originalValue = ACADPref.XRefFadeIntensity
    MsgBox "The XRefFadeIntensity preference is: " & originalValue
    ' Modify the XRefFadeIntensity preference by setting it to 75
    ACADPref.XRefFadeIntensity = 75
    newValue = ACADPref.XRefFadeIntensity
    MsgBox "The XRefFadeIntensity preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.XRefFadeIntensity = originalValue
    MsgBox "The XRefFadeIntensity preference was reset back to: " & originalValue
(defun c:Example_XRefFadeIntensity()
    ;; This example reads and modifies the preference value that controls
    ;; the dimming intensity for xrefs. When finished, this example resets
    ;; the preference value back to its original value.
    ;; * Note: Changes can only be observed when in-place editing of an Xref
    ;; object is in progress and other entities are visible.
    (setq originalValue (vla-get-XRefFadeIntensity (vla-get-Display preferences)))
    (alert (strcat "The XRefFadeIntensity preference is: " (itoa originalValue)))
    ;; Modify the XRefFadeIntensity preference by setting it to 75
    (vla-put-XRefFadeIntensity (vla-get-Display preferences) 75)
    (alert (strcat "The XRefFadeIntensity preference has been set to: " (itoa (vla-get-XRefFadeIntensity (vla-get-Display preferences)))))
    ;;         this preference in effect
    (vla-put-XRefFadeIntensity (vla-get-Display preferences) originalValue)
    (alert (strcat "The XRefFadeIntensity preference was reset back to: " (itoa (vla-get-XRefFadeIntensity (vla-get-Display preferences)))))
GMT+8, 2026-10-28 19:38
