XRefDemandLoad 属性 (ActiveX)
指定外部参照的按需加载。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acXRefDemandLoad
言论按需加载通过仅加载重新生成当前图形所需的参照图形的零件来提高性能。 此属性的初始值为 。acDemandLoadEnabled 注意:此属性的值存储在 XLOADCTL 系统变量中。
例子VBA: Sub Example_XRefDemandLoad()
' XRefDemandLoad. It then changes the value, and finally
Dim currXRefDemandLoad As Integer
Dim constant As String
Dim newConstant As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current XRefDemandLoad value
currXRefDemandLoad = preferences.OpenSave.XrefDemandLoad
constant = Choose(currXRefDemandLoad + 1, "acDemandLoadDisabled", "acDemandLoadEnabled", "acDemandLoadEnabledWithCopy")
MsgBox "The current value for XRefDemandLoad is " & constant, vbInformation, "XRefDemandLoad Example"
' Change the value for XRefDemandLoad
newConstant = "acDemandLoadEnabledWithCopy"
preferences.OpenSave.XrefDemandLoad = acDemandLoadEnabledWithCopy
MsgBox "The new value for XRefDemandLoad is " & newConstant, vbInformation, "XRefDemandLoad Example"
' Reset XRefDemandLoad to its original value
preferences.OpenSave.XrefDemandLoad = currXRefDemandLoad
MsgBox "The XRefDemandLoad value is reset to " & constant, vbInformation, "XRefDemandLoad Example"
可视化 LISP: (vl-load-com)
(defun c:Example_XRefDemandLoad()
;; XRefDemandLoad. It then changes the value, and finally
;; Retrieve the current XRefDemandLoad value
(setq currXRefDemandLoad (vla-get-XrefDemandLoad (vla-get-OpenSave preferences)))
(setq constant (cond
((= currXRefDemandLoad acDemandLoadDisabled) "acDemandLoadDisabled")
((= currXRefDemandLoad acDemandLoadEnabled) "acDemandLoadEnabled")
((= currXRefDemandLoad acDemandLoadEnabledWithCopy) "acDemandLoadEnabledWithCopy")
(alert (strcat "The current value for XRefDemandLoad is " constant))
;; Change the value for XRefDemandLoad
(setq newConstant "acDemandLoadDisabled")
(vla-put-XrefDemandLoad (vla-get-OpenSave preferences) acDemandLoadDisabled)
(alert (strcat "The new value for XRefDemandLoad is " newConstant))
;; Reset XRefDemandLoad to its original value
(vla-put-XrefDemandLoad (vla-get-OpenSave preferences) currXRefDemandLoad)
(alert (strcat "The XRefDemandLoad value is reset to " constant))
GMT+8, 2026-10-27 14:13
