WindowTitle 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 730| 评论: 0|原作者: admin|来自: AutoCAD
获取文档窗口的标题。
object.WindowTitle
类别: 文档
此属性应用于的对象。
只读:是的
类型:字符串
文档的窗口标题。
Sub Example_WindowTitle()
    ' This example cycles through the documents collection
    ' and uses the WindowTitle property to create a list of all open documents.
    Dim DOC As AcadDocument
    Dim msg As String
    ' If there are no open documents, then exit
    If Documents.count = 0 Then
        MsgBox "There are no open documents!"
        Exit Sub
    End If
    msg = vbCrLf    ' Start with a space
    ' Cycle through all open drawings and get the window title of each drawing
    For Each DOC In Documents
        msg = msg & DOC.WindowTitle
    Next
    ' Display a list of open drawings
    MsgBox "The open drawing titles are: " & msg
(defun c:Example_WindowTitle()
    ;; This example cycles through the documents collection
    ;; and uses the WindowTitle property to create a list of all open documents.
    ;; If there are no open documents, then exit
    (if (> (vla-get-Count (vla-get-Documents acadObj)) 0)
        (progn
            (setq msg "")
            ;; Cycle through all open drawings and get the window title of each drawing
            (vlax-for DOC (vla-get-Documents acadObj)
                (setq msg (strcat msg "\n" (vla-get-WindowTitle DOC)))
            ;; Display a list of open drawings
            (alert (strcat "The open drawing titles are: " msg))
        (alert "There are no open documents!")
GMT+8, 2026-10-28 11:12
