Volume 属性 (ActiveX)
2024-5-18 17:53| 发布者: admin| 查看: 1017| 评论: 0|原作者: admin|来自: AutoCAD
Volume 属性 (ActiveX)
获取实体的体积。
object.Volume
类型: 3DSolid
此属性应用于的对象。
只读:是的
类型:双
固体的体积。
Sub Example_Volume()
    ' This example creates a box in model space.
    ' It then returns the Volume for that box.
    Dim boxObj As Acad3DSolid
    Dim length As Double, width As Double, height As Double
    Dim center(0 To 2) As Double
    ' Define the box
    center(0) = 5#: center(1) = 5#: center(2) = 0
    length = 5#: width = 7: height = 10#
    ' Create the box (3DSolid) object in model space
    Set boxObj = ThisDrawing.ModelSpace.AddBox(center, length, width, height)
    ' Change the viewing direction of the viewport to better see the box
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
    ThisDrawing.ActiveViewport.direction = NewDirection
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    ZoomAll
    ' Return the Volume for the box
    Dim Volume As Double
    Volume = boxObj.Volume
    MsgBox "The Volume for the box is " & Volume, , "Volume Example"
(defun c:Example_Volume()
    ;; This example creates a box in model space.
    ;; It then returns the Volume for that box.
    ;; Define the box
    (setq center (vlax-3d-point 5 5 0)
          boxLength 5
	  boxWidth 7
	  boxHeight 10)
    ;; Create the box (3DSolid) object in model space
    (setq boxObj (vla-AddBox modelSpace center boxLength boxWidth boxHeight))
    ;; Change the viewing direction of the viewport to better see the box
    (setq NewDirection (vlax-3d-point -1 -1 1))
    (setq activeViewport (vla-get-ActiveViewport doc))
    (vla-put-Direction activeViewport NewDirection)
    (vla-put-ActiveViewport doc activeViewport)
    (vla-ZoomAll acadObj)
    ;; Return the Volume for the box
    (setq volume (vla-get-Volume boxObj))
    (alert (strcat "The Volume for the box is " (rtos volume 2)))
GMT+8, 2026-10-28 09:50
