Viewports 属性 (ActiveX)
获取文档的 Viewports 集合。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_Viewports()
' This example finds the current Viewports collection and
' adds a new viewport to that collection.
Dim viewportColl As AcadViewports
Set viewportColl = ThisDrawing.Viewports
' Create a viewport named "TEST" in the current drawing
Dim viewportObj As AcadViewport
Set viewportObj = viewportColl.Add("TEST")
MsgBox "A new viewport called " & viewportObj.name & " has been added to the Viewports collection.", vbInformation, "Viewports Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Viewports()
;; This example finds the current Viewports collection and
;; adds a new viewport to that collection.
(setq viewportColl (vla-get-Viewports doc))
;; Create a viewport named "TEST" in the current drawing
(setq viewportObj (vla-Add viewportColl "TEST"))
(alert (strcat "A new viewport called " (vla-get-Name viewportObj) " has been added to the Viewports collection."))
GMT+8, 2026-10-28 03:59
